20 Most Recent Xantrex Technology Xantrex Technologies 813-1000-00 XPower 1000 Watt Inverter Questions & Answers
2answers
Trace / Xantrex SW5548 inverter (one of two in a
hi i have trace sw5548 and the power keep turning off and i have to go in P G and E power, why would it keep turning off thanks
7/9/2011 9:33:06 PM • Xantrex... • Answered on Jul 09, 2011
I have 4 stacked xantrex sw+5548 inverters. The
Thank you for allowing us to help, please respond with further questions and concerns
Spanish speaking available for all problems
Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
PLEASE do not forget to award/PROVIDE "POSITIVE" FEEDBACK
PROVIDING FEEDBACK WILL ALLOW US TO CONTINUE SUPPORTING YOU IN EXPERT SOLUTIONS Before you leave feedback, ensure that your concerns and problems are addressed completely with me.
Hello, thank you for sharing your problem with us, I would personally be happy to provide the most accurate and up to date information for you.
Hello, your direct question is "Do I need to replace again the inverter or are the settings off-I went to factory default?"
There is no need to change the inverter at this time. When you set the device at factory default, it caused a MISCONFIGURATION between the "Diasy Chained" inverters.
SOLUTION
1. CAUTION - YOUR WORKING WITH HIGH VOLTAGE REGULATION AND INVERTERS
2. POWER OFF YOUR DEVICES AS LONG AS IT IS SAFE TO DO SO.
3. ONLY POWER UP YOUR INVERTERS FIRST
4. PROVIDE SEVERAL MINUTES WAIT TIME UNTIL EACH OF YOUR INVERTERS ARE COMPLETELY BOOTED
5. FEEL FREE TO INITIATE THE AC ALTERNATING CURRENT SOURCE AT THIS TIME
6. WAIT SEVERAL MINUTES TO ALLOW THE CURRENT TO RUN THROUGH THE COMPLETE CIRCUIT OR INVERTER DAISY CHAIN.
PLEASE RETURN IF YOU REQUIRE FURTHER HELP ON YOUR SAME PROBLEM.
THANK YOU
1/11/2011 4:27:17 AM • Xantrex... • Answered on Jan 11, 2011
0answers
Red fault light
Be the first to answer 5/8/2009 3:51:29 PM • Xantrex... • Posted on May 08, 2009Be the first to answer
When plugged in to electricity the display panel goes to bul then ab5 and the controls flash and the fan runs all the time
is there a switch to switch over from solar to normal electricity
7/11/2021 11:04:07 PM • Xantrex... • Answered on Jul 11, 2021
I hadnever used my Xantrex Prosine 1800i 250/240 V
Unfortunately, if you put AC power on the output of the inverter, you have likely blown the output transistors. Although the inverter can produce AC, they generally do not survive AC from some other source being put onto the output. MY guess is that the inverter is shot, but repairable. Sorry for the bad news. If I were you, I would call Xantrex and see what they say.
1/9/2018 9:56:03 PM • Xantrex... • Answered on Jan 09, 2018
I really screwed up this time! My daughter was
The red light fault you experienced was from the short, which caused an 'overload' on the device. It is designed to shut itself down under such conditions so as to not cause major harm to the unit. It may correct the fault indication after the short is removed (ie: no more playing with electronics when you are not so trained), and the unit should work again. Your mention of the fuses being in a "very tight spot" is typical in most such devices to make them as small and inconspicuous as possible. Working on such devices requires the technical expertise in dismantling and testing, then making needed repairs before again restoring the proper construction. Be very careful because you can damage other components by not handling carefully, and with the proper equipment.
4/20/2017 4:36:02 PM • Xantrex... • Answered on Apr 20, 2017
2answers
When I turn it on, why does it hum for 30 seconds then shuts off due to overheating?
If the output is shorted or if there's a problem in the inverter itself, such as a bad diode or such, then it will do that. Humming beyond a little sound is an indication that it's pulling too much power.
10/16/2015 5:48:21 PM • Xantrex... • Answered on Oct 16, 2015
tip
Xantrex inverter error codes
This information expands upon the error code information contained in the Link 2000 Owner?s Manual. E-01 Inverter high DC/Battery voltage shutdown Battery voltage has risen above 15.5 VDC for 12-volt models or 31 VDC for 24-volt models. E-02 Inverter low DC/Battery voltage shutdown Battery voltage has dropped below 10 VDC for 12-volt units or 20 VDC for 24-volt units. E-03 Inverter or Charger overtemp shutdown Unit will reset automatically after it has cooled sufficiently. E-04 Battery overload Caused by excessively discharged batteries. See section in inverter owner?s manual titled ?Charging overdischarged batteries.? E-05 AC Backfeed AC power from an outside source has been fed to the AC output of the inverter. Potentially damaging to the unit. Disconnect incoming AC power and correct the situation. E-06 Electronic Overload Inverter overload caused by too large a load or a short circuit. Reset by cycling power switch or connecting incoming AC power. E-07 Triac control error Triac has overheated. Shut down unit and allow to cool. E-08 High battery voltage shutdown during charge mode Check all charging sources for proper voltage. Reset by cycling the power switch. E-09 Spare E-10 Link 2000 de-powered This indicates that power was removed and restored to the Link 2000. E-11 Spare E-12 Battery #1 voltage sense leads open Blue wire is not connected to battery #1. E-13 Battery #2 voltage sense leads open Violet wire is not connected to battery #2. E-14 Inappropriate Charged V selected for sensed voltage This value defaults to 13.2 for a 12-volt system, 26.4 for a 24-volt system. If this setting is above the voltage limits of the charging source, this error code will be displayed. Please refer to page 9 of the Link 2000 Owner?s Manual E-15 Incoming AC polarity reversed Check incoming AC wiring for a reverse polarity condition. CCC Indicates battery being charged. Displayed when Time remaining is selected. LO BAT More than 50% of declared capacity of battery 1 or battery 3 has been consumed. OL Meter reading out of range U xx Designates a user setup CEF. Please read the sections pertaining to CEF on pages 19?22. A Designates Alternator output current on a Link 2000-R. is a number from 1?200. P Indicates Percent of charge mode selected. is a number from 1?100.
Inverter problems
3K is a big inverter. Depending on mfr, though, inverters put out numbers for PEAK, not AVERAGE Watts, and have trouble supplying large amounts of surge current on demand. Some appliances with large motors present large turn-on demand, like A/C's, washers, ovens, and fridges and will give converters trouble. Your Microwave, if it's a big one, like a 1.2 or 1.3KW will ask for a lot of juice when it first turns on. But once it's on for a few seconds will probably be OK. Get a bigger or different inverter, or a smaller microwave.
8/1/2014 5:44:51 PM • Xantrex... • Answered on Aug 01, 2014
Xantrax xw6048 with 30 each 235w orion poly solar
Yes. That's what that means. 3 strings of series wired panels. Now, the panels are going to be around 30 volts (vmp), so it all depends on the input voltage of that unit. I'd check the voltage range of the charge controller. If it's limited to lets say, 192 volts max for a 48 volt system, you can do 3 strings of 6 panels to keep it under the voltage.This will give you a 4230W panel output every hour, which is substantial.
10/18/2013 8:31:34 PM • Xantrex... • Answered on Oct 18, 2013
0answers
0answers
Xm1800 blown fuse
Be the first to answer 4/21/2013 4:25:48 AM • Xantrex... • Posted on Apr 21, 2013Be the first to answer
0answers
My TV suddenly went off
get it checked from a profesional and do not connect anything with it...
it is malfunctioning...
3/10/2011 5:06:15 AM • Xantrex... • Answered on Mar 10, 2011
Hello I have 40 foot
Your Freedom 458 has died. At this point, you need to isolate the batteries from the inverter / charger unit to prevent further risk of fire.
It is normal, with the fried charger, for the battery voltage to plummet even while plugged in. There is no converter to maintain them. When you start your rig, the alternator on the engine is charging the batteries. With the rapid drop in battery voltage, your inverter likely is shorted.
Remove the main battery fuse between the inverter and batteries, as well as unplug / turn off the breaker to the inverter /charger. Take your coach to the nearet service center, as it may still be under (partial?) warranty.
8/30/2010 10:33:56 PM • Xantrex... • Answered on Aug 30, 2010
HAVE 2 STACKED SW4024S, AFTER
Check you line out distribution leads for a system ground with the #2 inverter disconnected. Also chect across the line out terminals onthe inverter with the distribution leads disconnected. The inverters use a floating ground vs and installed ground. If the inverter senses a ground your will read 120VAC to ground on each output terminal bu\out will read ZERO across the two terminals. If you read 120VAC across the to terminals with the dristribution leads disconnected and lose that output voltage with the leads connected then you have introduced a FIXED ground into the system. You will need to isolate where the fixed ground manifested itself as a result of connecting the new water heater.
Thanks for choosing FixYa.
Kelly
8/27/2010 7:49:31 PM • Xantrex... • Answered on Aug 27, 2010
XANTREX S M Inverter off grid (I need a delayed start )
U may check the manual for xantrex
http://www.xantrex.com/web/id/275/DocServe.aspx
Take care.
1/26/2009 12:21:52 AM • Xantrex... • Answered on Jan 26, 2009
Xantrex Technology Xantrex Technologies 813-1000-00 XPower 1000 Watt Inverter Logo
5 questions posted
Top Xantrex Technology Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Xantrex Technology Electronics - Others
Most Popular Question
trace xantrex sw5548 inverter one two in
  • Electronics - Others
