20 Most Recent
Hitachi M12V2 3Router Questions & Answers
Bit wont tighten down in
Get a new collet and nut the 1/2" collet is crappy, it is too thin and pushes out of the nut easily.
You may also make sure that the collet did not seperate from the nut. remove the nut completely and if the collet is not attached, remove the collet from the spindle, insert inthe nut and then insert the bit through the collet while holding it and then put the hole thing back on the spindle (mtor shaft) and tighten it.
How do you change the collets on the Hitachi
Matt,
Remove the collet nut completely. The collet should come right out of the end of the motor shaft. Put the other collet in it's place and replace the same nut. I assume you are switching between 1/2 inch and 1/4 inch tools.
Hi, I have been stumped! I rebuilt a Hitachi
This is the Cars and Trucks section of Fixya. You might get more answers listing in another area of Fixya which more closely matches your device.All things considered, maybe apply air pressure and stick the unit under water in a utility sink or big wash tub. Air leaks would bubble like a hole in a tire tube.
Hitachi nailer doesn't fire, it has no leaks. When trigger is pulled there is no back pressure from trigger
I've had that happen before and what I found was one of the Staples or nails had misfired and wedged before leaving the gun. read the manual on how to get to it for that particular model and also it might be a good idea to adjust your pressure accordingly to keep it from happening again. If the force isn't set proper then a nail could Jam , block the mouth and not allow any other nails to exit. It's very easy to do and not that hard to fix once you've done it at least once. Good luck.
