20 Most Recent Hitachi NR90GC 3 1/2" Gas Powered Clipped Head Framing Nailer Questions & Answers
Maybe there can be a problem with a rip in the cilinder its a very thin cilinder and its neccesary to replace with all the parts on it because of the extreme heat build up.
cilinder assy 42 41A possible necessary, but first inspect the cilinder carefully on a rift. some other rings or parts broken or worn.
Hitachi NR90GC 3 1 2 Gas Powered Clipped Head Framing Nailer Parts
Hitachi NR90GC 3... | Answered on Oct 12, 2016
There's a tiny set screw holding it on.
Hitachi NR90GC 3... | Answered on May 27, 2015
Could be bad gas canister or needs cleaning. How many boxes of nails You shot thru that tool?
Hitachi NR90GC 3... | Answered on Feb 04, 2015
Hi, had the same problem. After market micro switch replacement for Hitachi NR 90GC from RS Components Stock number 682-1888 MPN; D2HWC203MR.
Note; this requires soldering in with heatshrink and cutting flyleads to correct length. Part of the alignment issue can be the handle screws working loose over time with use. Don't force anything back when assembling and use a little grease on contact parts.
Hitachi NR90GC 3... | Answered on Mar 07, 2013
If you mean the plastic top for the gas cylinder you should get 1 with every box of nails containing cylinders purchased.
Hitachi NR90GC 3... | Answered on Dec 19, 2011
Go to this LINK and find the part/diagram that can help you.
Hitachi NR90GC 3... | Answered on Nov 04, 2010
Hitachi NR90GC 3 1/2" Gas Powered Clipped Head Framing Nailer Logo
35 questions posted
Top Hitachi Tools & Hardware - Others Experts
John Trevino
Lance Guthrie
Lance Guthrie
Level 1 Expert
Roger Paull III
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Tools & Hardware - Others
Most Popular Question
faulty micro switch in hitachi nr90gc
  • Tools & Hardware - Others
