20 Most Recent Stairmaster 3800RC Recumbent Exercise Bike Questions & Answers
Have a stairmaster recumbant bike
If the bike is working with Battery, Replace with alkaline batteries, and clean very well the spring with special electronic cleaner contacts, you can buy in any electronic stores. 2) Tight the connector well, and clean with cleaner contacts. 3) See if the small motor inside is working good, or the wires is faulty , and repair or replace. LUBE very well the bike, follow the instruction manual steps. Blessing. [email protected] cell+whatsAPP:+50588611441 How to Lubricate an Elliptical Fitness Exercise Equipment
11/24/2017 12:15:53 PM • Stairmaster... • Answered on Nov 24, 2017
Programmed workouts do not start
i just want a manuel for a champion 33t recumbert bike
2/5/2015 4:06:51 PM • Stairmaster... • Answered on Feb 05, 2015
I'm looking for a manual for this piece of
This link will take you to the owner's manual for the 3800RC http://www.sportsmith.net/images/product_support%5Cstairmaster%5CManuals%5C3400CE_3800RC%20Momentum%20Manual.pdf and this link will take you to the parts available for that model: Stairmaster 3800 RC Momentum Recumbent Bike Parts SPORTSMITH net
11/12/2014 3:50:04 PM • Stairmaster... • Answered on Nov 12, 2014
Need foot straps for excel recumbent bike
This link will take you to the parts for the 3800RC. Stairmaster 3800 RC Momentum Recumbent Bike Parts SPORTSMITH net
11/12/2014 3:45:27 PM • Stairmaster... • Answered on Nov 12, 2014
Where do i get an owners manual for a recumbent bike 3800
8/13/2014 7:35:52 PM • Stairmaster... • Answered on Aug 13, 2014
Bike reads configuration required
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100. Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
8/1/2014 2:47:28 PM • Stairmaster... • Answered on Aug 01, 2014
Stairmaster 3800 Display screen reads "CONFIG
7/25/2014 10:05:15 PM • Stairmaster... • Answered on Jul 25, 2014
Where can I find a user manual for my Stairmaster
Here is a link for the manual for the 3800RC http://www.sportsmith.net/images/product_support%5Cstairmaster%5CManuals%5C3400CE_3800RC%20Momentum%20Manual.pdf
7/25/2014 10:02:10 PM • Stairmaster... • Answered on Jul 25, 2014
Need manual
Here is a link to the manual for the 3800RC http://www.sportsmith.net/images/product_support%5Cstairmaster%5CManuals%5C3400CE_3800RC%20Momentum%20Manual.pdf
7/25/2014 10:01:05 PM • Stairmaster... • Answered on Jul 25, 2014
How can I fix program screen on my Stairmaster 3800RC Recumbent Exercise Bike?
If you have not used your machine in about a year, most likely the battery is dead. You can find most of the parts you may need here: Stairmaster 3800 RC Momentum Recumbent Bike Parts SPORTSMITH net
7/25/2014 9:59:39 PM • Stairmaster... • Answered on Jul 25, 2014
Battery charger for 3800 RC
This link will take you to the product you are needing. The technology inside the power supply allows it to adjust to the voltage required to charge the battery on the 3800RC. Power Supply Kit with Plastic Output Connector Domestic Stairmaster...
5/6/2014 2:51:06 PM • Stairmaster... • Answered on May 06, 2014
Screen flashes when trying to operate
If you have not already done so, start with checking the battery voltage. It should be at least 6 volts DC. Check the link attached for instructions on how to properly check the voltage on a battery. Video about How to Test Battery
4/30/2014 9:57:20 PM • Stairmaster... • Answered on Apr 30, 2014
Set program and the screen starts flashing
is the panel run on batteries?
10/21/2013 10:53:41 PM • Stairmaster... • Answered on Oct 21, 2013
0answers
Looking for battery charger for stairmaster 3800RC
contact sportsmith fitness products you can find them on the internet
2/3/2011 4:13:29 AM • Stairmaster... • Answered on Feb 03, 2011
Have a problem,set the workout
first plug the unit in with the adapter, then try ,if all ok then let battery charge 24 hrs if it does not run after you unplug it check all wiring connections .if all ok then have alternator checked
2/3/2011 3:49:11 AM • Stairmaster... • Answered on Feb 03, 2011
I need a replacment power cord that was lost in a
call sportsmith fitness products you can find them on the internet
2/3/2011 3:17:51 AM • Stairmaster... • Answered on Feb 03, 2011
Stairmaster 3800RC Recumbent Exercise Bike Logo
28 questions posted
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Larry Ng
Larry Ng
ADMIN Andrew
ADMIN Andrew
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Stairmaster Exercise & Fitness
Most Popular Question
  • Exercise & Fitness
