20 Most Recent Stairmaster Stepmill 7000 Pt Questions & Answers
2answers
7000 PT will not start up (display flashes)
On that relay board their should be 2 lights engaged:
1.power 2.relay.
It sound like a loose connections there are 3 connections to the board first that I would look is the power connections to see if their is no broken wires, than the connector that goes to the display that may have exposed wires that may be grounding out on the frame and by jostling the connectors and see if either one stops the light flickering and relay clicking.Their can be also cold soldier connection on the relay board. Hope this helps
4/1/2022 1:52:26 AM • Stairmaster... • Answered on Apr 01, 2022
When the power is on the stepper wont slow down
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH This sounds like a possible console issue. You can use the following link for more troubelshooting information. Search Results
7/13/2016 8:50:54 PM • Stairmaster... • Answered on Jul 13, 2016
My Stairmaster 7000PT has no resistance past level 10 or 11?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH This could be caused by worn alternator brushes. The following link will take you to a video on testing the alternator. If the alternator checks out, you may be dealing with a faulty display console. Video about Performing Jumper Test on Stairmaster Alternator
11/4/2015 5:26:28 PM • Stairmaster... • Answered on Nov 04, 2015
Belt slips off stairmaster stepmill
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH There are a couple of different belts available for this unit. The following link will take you to the parts available for your model. Stairmaster Stepper 7000PT Stepmill Parts Transmission SPORTSMITH net
11/4/2015 5:23:29 PM • Stairmaster... • Answered on Nov 04, 2015
Stepmill 7000 PT cs com error
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH This is a communication error. Start by confirming continuity in the wiring harness. The following link will show how to use a multimeter. Video about Multimeter Testing
10/12/2015 4:05:55 PM • Stairmaster... • Answered on Oct 12, 2015
Stairs won't speed up or slow down
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH You should start by verifying that your relay board is functioning properly. The following videos will help you through the troubleshooting of this issue.
10/1/2015 9:02:09 PM • Stairmaster... • Answered on Oct 01, 2015
Stair climber
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Start with verifying the relay board is functioning properly. The following is a video to aid in the troubleshooting process.
10/1/2015 8:55:48 PM • Stairmaster... • Answered on Oct 01, 2015
My stairmaster 7000pt's screen won'tt turn on it keeps displaying
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Is this even after you begin stepping on the unit?
9/30/2015 4:35:27 PM • Stairmaster... • Answered on Sep 30, 2015
I just bought a stairmaster 7000pt with a broken console screen. I replaced all the broken parts but it's still not working. Any ideas?
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100. Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
9/18/2015 9:19:43 PM • Stairmaster... • Answered on Sep 18, 2015
tip
Too Much Resistance on Stepmill
The first step in troubleshooting too much resistance or constant resistance begins with the lower board. You will want to first verify that the Field LED is lit on the lower board. As shown in the video, the Field LED is off initially, when the steps are engaged it lights up, after about 5 seconds the light should go off. If the Field LED stays lit during a workout or after a workout is completed, this is a sign that the console is faulty. There is constant power being supplied through the console keeping a full load and causing no change in resistance. If the Field LED remains lit, the console needs replaced. Too Much Resistance Troubleshooting Video for Stairmaster Stepmill SM916
I have problem with master console of step mill
If you have a Stairmaster Stepmill 7000PT that has an older style console with the red LEDs and you want to upgrade to the newer, console with the blue LCD; the parts necessary for this upgrade include the console and the console cable. Stairmaster Stepmill 7000PT Console Upgrade C40 Console Repair Video for Stairmaster Steppers
2/11/2015 5:23:17 PM • Stairmaster... • Answered on Feb 11, 2015
Stairmaster Stepmill 7000 Pt Logo
Popular Tags
83 questions posted
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Larry Ng
Larry Ng
ADMIN Andrew
ADMIN Andrew
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Stairmaster Exercise & Fitness
Most Popular Question
stairmaster run normaly few minutes spin
  • Exercise & Fitness
