20 Most Recent Samsung WF206ANS Front Load Washer Questions & Answers
Where can I purchase a control board for a Samsung
Samsung Parts has the Function and Main PCB board, as well as other parts here: http://www.samsungparts.com/Products/Parts_and_Accessories/WF206BNW/Default.aspx . The control panel is at http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DC97-12075B.aspx?model=WF206BNW . The function and Main PCB board is available at: http://www.samsungparts.com/Products/Parts_and_Accessories/PID-MFS-WF206L-T0.aspx?model=WF206BNW . Partstore.com also has some parts: http://www.partstore.com/Model/Samsung/Samsung/WF206BNWXAA.aspx .
I hope this helps.
11/11/2019 1:44:48 AM • Samsung WF206ANS... • Answered on Nov 11, 2019
I just got my pump replaced and now i need to reset my samsung washer it still shows nd and stops
The problem is probably in the control panel or water level switch. I just posted a procedure to clean the relay contacts for the pump motor relay. This little relay is on the control circuit board and is not normally customer accessible. But the alternative is purchasing a new control circuit board (which in my case was not available) or replacing the washer. Please refer to my solution for the problem "Drain Pump doesn't work" posted today.
12/17/2014 1:33:12 AM • Samsung WF206ANS... • Answered on Dec 17, 2014
What size belt do i need two pulley 38 inch cut
Washer belt aren't givin out on size, they are model specific. Because not only circumference but thickness and compound so use the washers model / serial number to get the correct one
6/7/2014 10:38:27 AM • Samsung WF206ANS... • Answered on Jun 07, 2014
What size of belt do i need for a two pulley deck 38 inch cut
If the belt is broken , lay it flat and measure it. Take 1/2 inch off for stretch and get a new one at that length. If you can't read the numbers on the belt and it isn't broken, mark the back of the belt and measure the belt from one side of the mark all the way around the back of the belt to the mark again. Do the stretch 1/2 in and get the new belt size that way.
6/7/2014 8:04:53 AM • Samsung WF206ANS... • Answered on Jun 07, 2014
Door wont open
Turn on a cycle and wait for it to start. should fix the problem
4/22/2014 3:25:40 AM • Samsung WF206ANS... • Answered on Apr 22, 2014
How to change belt
Check the belt at the back, there is a small compartment where you will have to take off 4 screws and a door. Otherwise check the inside of the tub and the drum. Something maybe caught in between.
1/17/2014 6:32:29 AM • Samsung WF206ANS... • Answered on Jan 17, 2014
Error message of
That means overflow. There is too much water in the drum. Turn the unit off and it should drain. If not then it might be a sensor that is bad.
12/3/2013 12:14:55 AM • Samsung WF206ANS... • Answered on Dec 03, 2013
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts. Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain. When this washer error code comes up the washer will not spin either.To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front. If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise. If the front panel does not have the access panel the washer will need to be slide forward. With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible. Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.Put the washer back together and test for proper operation. If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
2/28/2013 1:53:41 PM • Samsung WF206ANS... • Answered on Feb 28, 2013
Samsung WF206ANS Front Load Washer Logo
74 questions posted
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Washing Machines
Most Popular Question
tried everything but front loader
  • Washing Machines
