20 Most Recent
EA Sports G4ME5 PreOrder NBA LIVE 09 Wii Game for Nintendo Wii Questions & Answers
The game makes a beeping noise and freezes our screen
Okay, first off, NEVER unplug your wii, even when it freezes. This may cause it to short out and will make the problem worse. There is a way you can turn the Wii off while it is in the frozen state.
Hold down the power button for a maximum of 15 seconds, and this will kill the power of the wii without damaging it.
Okay, now to fix the problem: The best thing you can try is to reformat your wii. If this doesn't work, then check to see if it's a glitch in the game itself. Because if this problem doesn't happen on other games, then that could be the problem. Check on the web to see if anyone else is having the same delema with that game, then compare problems.
Hopefuly this helped, it's not the best solution but it should work pretty well.
Player 2 doesn't work
hello i think you need press home wii remote settings reconnect wait do this with both controllers if this doesent work try this
go to multi player then to hold 1 and 2 and wait till second light comes on
if this doesent work try this:
open the battery casing. press the little red
button inside until the 4 lights on the front flash
then go over to the console and open the SD card cover on the front and press that little red button
then the controller is synced and your light will correspond to Wat player you are
hope i helped
2 players on nba live 09
if you mean just a 2 player game, press play now and make both players choose a team. if you mean 2 player dynasty/superstar or campaign features, that wont work.
Xbox 360 will not read my disk
do all your disks do this? if so it could be your xboxs reading lense, if not it may just be sheer coincidence the second disk didnt work, this once happened to a friend of mine, exept with gta4
I'Ve scratched my Fifa 10 disc.
EA will not replace your game disc. This happens to many gamers and it's not something they take responsibility for.
So your disc is officially garbage. But you're not completely out of luck. Do what I did. Go to
sellitbroken.com and sell your game to them. They will give you good money for it.
Will fifa 11 work on ati hd 4750??
Minimum System Requirements for Fifa 11:
Operating System : Microsoft Windows XP / Windows Vista / Windows 7
Processor : Intel Core 2 Duo at 1.8 GHz / Athlon 64 X2 Dual Core 5400+
Video Card : 256 MB VRAM - (NVIDIA GeForce 6800 or better / ATI Radeon X1600 or better) **
Memory : 1 GB RAM (2 GB required for Windows Vista / Windows 7)
Hard Disk : 6.5 GB of free Hard Drive space
Sound Card: DirectX 9.0c Compatible
Direct X : 9.0c
Controls : Keyboard & Mouse
Installation : DVD-ROM Drive
**Supported Chipsets :
NVIDIA GeForce® 6xxx series (6800 or greater)
NVIDIA GeForce® 7xxx series
NVIDIA GeForce® 8xxx series
NVIDIA GeForce® 9xxx series
NVIDIA GeForce® GTX 2xx series
ATI Radeon™ X1600 (X1600 or greater)
ATI Radeon™ X1800
ATI Radeon™ X1900
ATI Radeon™ X1950
ATI Radeon™ HD 2xxx series
ATI Radeon™ HD 3xxx series
ATI Radeon™ HD 4xxx series
Yes, it will work on an ATI HD4750.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
Need serial codes for ea sports 2008 collection edition.
If you mean codes for items in the game, simply type into the google.com search engine - "Item Codes for EA Sports 2008 Collection Edition"
If you mean a serial code for the game installation, check the box that you bought it in, or if it was a digital copy check the email confirmation of whatever service you used.
Hope it helped!
I got the sims exp
the cd may be damage or the reader is faulty.
the file may be corrupted
