20 Most Recent LG WM2016CW Front Load Washer Questions & Answers
Not enough water getting in your machine make sure your inlet hose isn’t kinked or the water pressure hasn’t dropped.
LG WM2016CW... | Answered on May 06, 2019
call a technician
could be clothes jammed under or behind the agitator
LG WM2016CW... | Answered on Nov 28, 2017
unplug for 15 mins
LG WM2016CW... | Answered on Feb 23, 2017
normally pressing and holding start or stop will reset .removing drain hose from wall and holding at ground level will empty all washing machines.so have it in a bucket.either its not level so adjust feet so it cant rock about then dont overload it turn drum as u load that will help balance.
LG WM2016CW... | Answered on Nov 18, 2015
If you take the 3 screws off the back of the top metal panel and slide it back the door lock has a release cord you can pull to get your clothes out. You will need to replace the door lock if the problem continues.
If you need help finding the right part number let me know.
LG WM2016CW... | Answered on Sep 28, 2015
you sure it is not and upside down 'F' instead of an L? that would be a hall sensor(motor position sensor) error. easy fix. check out appliancepartspros.com or repairclinic.com for both parts and videos that show how to repair. very easy with common tools. about 20-30 minutes. basically take back cover off, remove motor cover, remove stator, replace part.
LG WM2016CW... | Answered on Sep 02, 2015
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
LG WM2016CW... | Answered on Aug 03, 2015
This type of washer spins at high speed and would break your arm if you put it in the washer while it is spinning. Bypassing the lock is not be a good idea. If you want to bypass, you will need a wiring diagram.
LG WM2016CW... | Answered on May 18, 2015
unplug it for a few minutes then plug back in
LG WM2016CW... | Answered on Mar 30, 2015
This is normal for HE front-loading washers. They have solenoid valves which open and close rapidly. This can cause a phenomenon known as "water hammer" in your pipes. You can purchase a unit to connect to the water lines to absorb the shock. It looks like below and you need one for the hot and another for the cold. I'm not sure where you are from, but I've supplied a link as well so you can see where you can purchase them.
Shop at NationalBuilderSupply com
LG WM2016CW... | Answered on Mar 23, 2015
Hi if you remove the pump again get a plug and wires example from a table lamp and attach 2 wires to the pump dont worry about polarity it will run both ways plug into the wall see if the pump runs out of the machine ( does this model have 2 pumps one could be the recirculation pump)
LG WM2016CW... | Answered on Dec 29, 2014
If its the main drum bearings gone then this will entail a complete strip to access them. The parts are available online, just have your serial no, model etc ready and trawl through various web appliance sites to find the best price. You will need a fair amount of mechanical / DIY knowledge to carry out this task. There are lots of parts and electrical connections.
LG WM2016CW... | Answered on Aug 05, 2014
you just have to pull it out and take back panel off start filling with water and watch and see where it coming from a few rubber hoses under there or water pump.
LG WM2016CW... | Answered on Jul 30, 2014
Check your owners manual, some models warranty the rear tub that houses the bearing and the inner spin basket. If not the rear outer tub and the gasket between both tubs will have to be replaced the correct the problem. If out of warranty it may not be cost effective to repair.
LG WM2016CW... | Answered on Apr 06, 2014
LG WM2016CW Front Load Washer Logo
Popular Tags
36 questions posted
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
water fills small amounts time slams
  • Washing Machines
