20 Most Recent
American Standard Traditional Champion4 2034.004.020 Whit Questions & Answers
How tight should I tighten
There is no torque value as far as I know. There should be rubber washers to minmize the chance of cracking the ceramic and to provide a water seal.
But to try to give some sort of guideline, on a scale of 1 - 10, I'd say a 6 would be about right -- or perhaps you could call that medium tight. In any event, the bolts have to be tight enough to prevent leaking -- if it leaks, you'll have to keep tightening.
Charlie
3/28/2011 6:02:44 AM •
American...
Answered
on Mar 28, 2011
Air switch randomly comes on by itself and I have to leave the breaker off
This could be caused by a faulty relay or switch in the control panel. It is best to have a qualified technician inspect the control panel and replace any faulty components. If the issue persists after replacing the faulty components, then it could be a wiring issue and a qualified electrician should be consulted.
2/22/2023 9:40:24 PM •
American...
Answered
on Feb 22, 2023
My American standard champion 4 sings after I flush it, while it I still filling. Then stops when filled.
Hey, One thing is that maybe there might be some loose plastic shavings in the fill line. From the Factory? or maybe was inside the water line going to the toilet when you connected the line to toilet. Shut off the water and get some towels and something to catch the water and disconnect it from the toilet and use bowl or what ever to catch the water and slowly turn it on and see if anything comes out. Maybe if it is in the line inside the toilet it might fall out by lightly tapping on the fill line inside the toilet to help it fall out. Just a thought when you said it "Sings" that sounds like trash inside the line going to the filler tube and bowl, hey try it who knows it might work. Okay
7/12/2019 12:28:16 PM •
American...
Answered
on Jul 12, 2019
