20 Most Recent Oster 4134 / 4126 Classic Beehive Work Top Blender Questions & Answers
6answers
How do I replace the fuse on my Oster Blender?
I just had the same problem too and ordered the fuse online with the link above. Thanks lele44!
The four feet on the bottom are easily removed with a 1/4" socket slipped inside the each rubber foot fitting.
I'm glad I found you. I saw some downright horrible reviews of my local Oster appliance service center here:
http://www.insiderpages.com/b/3723327730
Rob
1/21/2019 8:38:28 PM • Oster 4134 /... • Answered on Jan 21, 2019
3answers
Square drive pin for Osterizer blenders?
I simply slid a small screwdriver in through one of the holes under the base to prevent the fan from spinning and unscrewed the pin counterclockwise using some small channel lock pliers. No disassembly necessary.
10/5/2013 11:27:21 AM • Oster 4134 /... • Answered on Oct 05, 2013
0answers
2answers
Osterizer blender problem
Is the black plastic part, seal, and glass portion snugly fitted together? If so, it's likely that the black plastic part isn't making contact with the pin. On mine I have to turn it about a quarter turn to lock it to the motor/ drive pin.
If I have a hard object such as ice cubes too firmed placed in the blender against the blade and the glass, I shake the container to loosen the materials and reseat it onto the drive pin as mentioned above.
9/4/2012 11:57:24 PM • Oster 4134 /... • Answered on Sep 04, 2012
0answers
Oster beehive rubber drive coupling and square drive pin
Most probably find a Oster parts manual here. Just send them a search request.
5/29/2009 12:06:19 PM • Oster 4134 /... • Answered on May 29, 2009
2answers
Osterizer
Thanks to some good leads, I determined the cause of the problem and ordered a part. Hopefully, that will resolve the problem.
3/1/2009 8:13:23 PM • Oster 4134 /... • Answered on Mar 01, 2009
Oseterizer 2spd Blender | Proper order of hardware related to fan
You should have four parts:
Shiny washer
Fan
Black spring-washer
Bolt
They assemble onto the driveshaft in that order.
3/1/2009 8:11:06 PM • Oster 4134 /... • Answered on Mar 01, 2009
Hamilton Beach blender rubber drive removal
plz cont -23051554 \ 23095757
8/5/2008 4:41:35 AM • Oster 4134 /... • Answered on Aug 05, 2008
Help with a Dismantled Osterizer Classic Blender
With the unit upside-down and the bottom off the wires on the right side of the switch go like this:
yellow on top
black on middle
red on the bottom
No wire connects to the 4th connection point (top left side).
R.
7/27/2008 5:24:01 AM • Oster 4134 /... • Answered on Jul 27, 2008
My rarely used Sunbeam Blender Model #4181 stopped working
It sounds like one of a number of things...
* The contacts in the switches fried
* The motor itself fried
* The controller section fried
If you saw smoke, something fried... probably cheaper to simply replace the unit. Even if it still worked, it's a 120V electric appliance used with liquids, and I wouldn't trust it... I'd hate to hear that your blender started a kitchen fire.
3/24/2008 7:48:32 PM • Oster 4134 /... • Answered on Mar 24, 2008
Oster blender pro 1200 stops prematurely and 2 present lights blink 3 times
It sounds like overheating or a control board failure. Contact the maker for a warranty claim https://www.google.com/search?q=Sunbeam+sfs001+manual ..
12/24/2022 9:07:42 PM • Oster Blenders • Answered on Dec 24, 2022
The fuse went out on my Oster Dual Action Blender BLSTRM-DZG-BG0. I've purchased multiple fuses but can't seem to find the correct size. Has anyone successfully replaced one of these fuses? If so, where did you find it? Thanks so much!
Same thing happen to my blinder, it uses 5A fuse 250V. But even if you replaced the fuse it still blow up... some other issue related that make the fuse blow
7/8/2021 11:34:50 PM • Oster Blenders • Answered on Jul 08, 2021
I do not know how to remove the coupling pin from my OsterĀ® 700 Watt 8 Speed Stand Blender. Can you please help me?
check the operator manual - and see the parts breakdown picture. the sequence of parts to remove to replace it would be evident from the pictures.
12/21/2018 11:44:50 AM • Oster Blenders • Answered on Dec 21, 2018
Where can I get a replacement fuse for my Oster precise blend 12?
Hello, Frances - Your question landed in the Fixya.com category of Furniture. I re-categorized your question to the Oster Blenders category. I found the following information regarding Oster blender built in fuses: (Quote) The built in fuse protection has kicked in. To turn the blender back on, first turn the control knob to "Off" and unplug the unit from the wall. Then remove the jar from the base and free the blade of any obstructions. Next, press the external resettable fuse button on the bottom of the base. Wait 30-45 minutes for the unit to cool. (End quote) Source: https://www.oster.com/service-and-support/product-support/product-faqs/blenders/oster-versa/blenders-oster-versa-faq.html?faq=blenders-oster-versa-faq-Q-A-4 Question: My blender shut off during use. What happened? If you try that possible solution and the blender still does not start, then . . .this is the link to the Oster Contact Us page: https://www.oster.com/customerservicecontact?cid=contactus At the very bottom of the page you will find toll free Customer Service phone numbers. Or . . . Fill in the form there, asking about the availability of a replacement fuse for your model of Oster blender, so that you can send an email message. Best wishes.
9/26/2018 6:05:08 PM • Oster Blenders • Answered on Sep 26, 2018
Where can i buy oster 4172 rubber rings
Sorry we do not have parts locators services here.
3/30/2018 11:06:02 PM • Oster Blenders • Answered on Mar 30, 2018
We have an OLD Oster blender model 442. It is over 50 years old. Problem is one of the seals is no longer usable. Anybody have any ideas on obtaining a seals for this antique.
there are compaies around that sell seals , bearings and "O" rings see if you have such an operation in your state and contact them with the measurements of the seal
3/14/2018 4:11:26 AM • Oster Blenders • Answered on Mar 14, 2018
No power light on the Oster 6700
Get it touch with a local Oster repair guy. Likely he can solve your problem, over the phone. You may need to take it to them.
3/4/2018 9:06:57 AM • Oster Blenders • Answered on Mar 04, 2018
Oster 4134 / 4126 Classic Beehive Work Top Blender Logo
21 questions posted
Top Oster Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Joaquin A Barahona ...
Are you an Oster Blender Expert? Answer questions, earn points and help others
View Most Popular
Oster Blenders
  • Oster Blenders
Most Popular Question
oseterizer 2spd blender proper order
  • Blenders
