20 Most Recent
Sharp R-1872 Convection/Microwave Oven Questions & Answers
Microwave part is not working
There are several possible causes... none of which are user serviceable. Take unit to a shop for repair.
Possible problems include door switch, Magnetron, rectifier, control relay, etc.
Just moved into a home with a Sharp
Yes, this is a common item. Any appliance store that handles the Sharp line will be able to order the racks for you, if they do not have them in stock.
Mounting brackets for Sharp R-1872
Did it have the installation instructions? That will list the part numbers you need.
If not, the original part number for the installation instructions was TINSEB371MRR0, which was replaced by TINSEB141MRR0. (both end in zero, not "oh")
You can get the latter via
Encompass (formerly Tritronics, the best place to get Sharp parts).
Or you can call them toll-free at 866-779-5835, which will get better results. They should also be able to tell you the parts you'd need to install it.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
What is the wattage for a sharp microwave model R-220AW? 1997
? de aproximadamente 600 watts. No entanto, ? importante notar que as informa??es espec?ficas sobre a pot?ncia podem variar ligeiramente dependendo do modelo exato e das condi??es de uso ao longo do tempo. Se voc? precisar de informa??es precisas sobre o modelo espec?fico que possui, recomendo consultar o manual do usu?rio ou entrar em contato diretamente com o fabricante.
Why Does My Sharp Microwave Turntable Get Hot?
I hope you didn't run the microwave with nothing in the cavity, if you did, it will damage the magnetron.
The turntable dishes do get hot depending on the quality of the glass used to make it. Heat is caused by impurities in the glass.
If you run it with no food in the oven, the glass will try to absorb the energy with atastrophic results usually.
My sharp Double Grill & Oven R795 will not heat up to temperature, when used as an oven . Microwave side is ok, can any body help
You might attempt the following troubleshooting steps:
Ensure sure the temperature settings are accurate and that you have given the oven enough time to warm before putting food inside. Check the oven temperature settings. To learn how to adjust the temperature properly, consult the user handbook.
Examine the heating components since they can be broken if the oven is not heating at all. When the oven is switched on, see if the heating components are blazing red. The heating components might need to be replaced if they are not.
Examine the oven thermostat: If the temperature fluctuates or fails to reach the desired level, the thermostat may be malfunctioning. Replace a broken thermostat if necessary.
Verify that there are no blockages inside the oven that could be preventing the heat from circulating. Debris, foil, or bakeware that is too big or that covers a significant amount of the oven rack might all fall under this category.
