20 Most Recent Sharp R-1214 Microwave Oven Questions & Answers
Our 2.5 year old Sharp R-1214 has started burning
Does this MW oven have a platter on a turntable?
1/4/2018 11:51:45 PM • Sharp R-1214... • Answered on Jan 04, 2018
Oven began to spark and smell. The waveguide cover broke apart & scorched side now won't heat. Clock/light work so does the turntable but groans. Is it fixable or done?
It is possible the magnetron may have been destroyed. Arcing in the waveguide would likely cause a significant increase of cathode to plate current through it; possibly melting it internally. You could also have failure of the high voltage rectifier; caused also by high current. If that's the only problem, then it's possibly repairable for a reasonable cost. You would have to repair and repainted the waveguide. Some waveguides have a vertical bar in them to aid in dispersion of the microwaves. If this is loose and shorting, then you'd have to replace the entire frame/cavity. Not very practical. If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
4/2/2016 7:34:48 PM • Sharp R-1214... • Answered on Apr 02, 2016
Sharp r1214f sparking
the container of these items probably contain some metal which doesnt go with the microwave
11/28/2013 7:11:09 PM • Sharp R-1214... • Answered on Nov 28, 2013
manual
Sharp R-1214F clock won't hold time. Have to reset after every use.
You may not actually be setting the clock fully.From page 16 of the owner's manual (online here):12_27_2012_10_37_53_pm.gifIf it still fails, you may have a failing keypad or moisture on the controller.See the service manuals here and here. You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
12/31/2012 11:05:08 AM • Sharp R-1214... • Answered on Dec 31, 2012
Sparks as if there was metal in oven
Unplug unit and take to repair shop--do not continue to try to use it.
8/30/2012 3:57:39 PM • Sharp R-1214... • Answered on Aug 30, 2012
0answers
2answers
Sharp r-1214 turntable problem
The turntable motor is starting seize, it will reach a point and stop working. The only option is to replace it.
4/24/2012 7:59:37 PM • Sharp R-1214... • Answered on Apr 24, 2012
0answers
Does not cook - no
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
3/14/2011 7:29:04 PM • Sharp R-1214... • Answered on Mar 14, 2011
My sharp 1214 won't heat anything. power is good
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
2/25/2011 3:53:43 PM • Sharp R-1214... • Answered on Feb 25, 2011
I can no longer see the numbers on the screen of
All you require is a new display. You may be able to source one from a trade sales online outlet. Try ebay for ideas or Google the type number with "faulty display" included in the search.
Hope this helps.
10/25/2010 2:48:59 PM • Sharp R-1214... • Answered on Oct 25, 2010
R-1214 Stainless Steel 1100 Watts Microwave Oven: turns on buts starts sparking in a few seconds. ...
what's sparking... is it by the Magnatron window... or the carousel?...
If there is a carousel... take it out...
if its by the magnatron window,,, then...houston... we have a problem...
might be contamination... and that may require opening up the unit... sorry...
hopefully it's only something floating around in there that's causing the arc... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
5/6/2010 7:06:54 PM • Sharp R-1214... • Answered on May 06, 2010
Defective turn table (not working).
opening a microwave oven is not recommended at consumer level due to hazardous internal componants. Seriously hazardous.
10/27/2009 2:10:10 PM • Sharp R-1214... • Answered on Oct 27, 2009
0answers
What is the wattage for a sharp microwave model R-220AW? 1997
? de aproximadamente 600 watts. No entanto, ? importante notar que as informa??es espec?ficas sobre a pot?ncia podem variar ligeiramente dependendo do modelo exato e das condi??es de uso ao longo do tempo. Se voc? precisar de informa??es precisas sobre o modelo espec?fico que possui, recomendo consultar o manual do usu?rio ou entrar em contato diretamente com o fabricante.
3/16/2024 5:08:07 PM • Sharp Microwave... • Answered on Mar 16, 2024
Sharp R-1214 Microwave Oven Logo
23 questions posted
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Microwave Ovens
Most Popular Question
sharp r 1214 turntable problem
  • Microwave Ovens
