20 Most Recent
Sportline Stopwatch Questions & Answers
Is there a way to stop the beep when you press the
There is no easy way to stop the beeping when you press start/stop on the timer. What I did was open up the unit. There are 4 small Phillips screws that hold the unit together. Unscrew them all. When opening the unit, be very careful of the buttons and the springs that may fly off. Then, on the back side of the timer is this silver metal disc (the speaker) with two white wires connected to it. Sever one of the wires. That should stop any and all beeping from the timer. Reassemble the unit.
Note: This will also disable all noise from the hourly chime and the alarm. No beeping noise will ever emit from this unit again. If you need beep back, re-solder the severed wire back to the speaker.
5/3/2017 8:30:13 PM •
Sportline...
Answered
on May 03, 2017
How do I turn off the alarm for the sportline 228
Hourly chime was my problem, not the alarm as I thought. After I turned off the alarm it still chimed on the hour. To turn off the hourly chime feature.
Press C then press and hold C and then Press A while still holding C until all the lines under each day of the week disappear.
6/2/2015 2:32:06 PM •
Sportline...
Answered
on Jun 02, 2015
How do i turn off my sportline 240 stopwatch?
you can find an exper in the local shop where you buy the product and they will give you specific service
for your questions about your product.
In addition, i like to play world of warcraft. there is a reliable website for
all players to get
cheap wow gold with the lowest price wihit in
7/25/2014 4:31:57 AM •
Sportline...
Answered
on Jul 25, 2014
Sportline 228 Stop watch
First a common understanding:
Split/Reset Select button = C
Mode button = A
Start/Stop Set button = B
Pressing B and C simultaneously turns the alarm on and off. The little sound waves on the right will appear and disappear.
Press and hold C - the alarm time will appear. You will probably notice a bar on the display under each day of the week.
While still holding C, press A. All the bars should disappear.
That should stop the watch from beeping on the hour. Good luck.
Dave.
Jer. 29:11
5/13/2014 5:59:10 AM •
Sportline...
Answered
on May 13, 2014
How to turn off beepiing and alarm
To set/Disable Hourly Chime/Alarm
Step#1.Press "Mode" (center button) until you are at "Time Display" (the home screen)
Step#2. Hold "Split/Reset" Button it will show the alarm time
Step#3. Keep holding Split/reset button and press the "Mode" (center button) "Hourly Chime Is On" when dashes appear above display (in alarm mode) "Hourly Chime is Off" When no dashes appear!!!!!!!!!!
1/3/2014 8:41:28 AM •
Sportline...
Answered
on Jan 03, 2014
Brand new stopwatch just out
These watches are despatched in a "power down mode" to conserve the battery while in storage.
Press any of the buttons and hold for 3 seconds and your watch should spring to life.
1/17/2011 3:22:55 PM •
Sportline...
Answered
on Jan 17, 2011
