20 Most Recent Nikon 8426 6-24x50 Monarch Side Focus Rifle Scope Questions & Answers
Very blury above 10 x no mater how i ajust it and
If you are trying to focus at a relatively close distance, you may be overpowering the scopes ability to focus at that distance. Most rifle scopes are set to parralax free at 100 yards.You can see this effect by putting the scope on its lowest power, focusing at 25-50 yards, and then increasing the power setting. You will see the image go out of focus as the power increases. This simply means that you must shoot at longer distances in order to use the scope to its full potential.
The other problem may be your parallax adjustment, but you may have already tried that solution.If not, make sure that the adjustment dial is set at the distance you are trying to shoot (minor adjustment from the indicated setting may be required to fine tune the image).
10/22/2010 4:45:28 AM • Nikon 8426... • Answered on Oct 22, 2010
I bought a pair of 10x42 Nikon binoculars about three weeks ago and am seeing double. How can I fix this?
Adjust the the width or the eyepieces as you are looking through them until you see a perfect circle. Sorry for the 5 year delay. Your post attracted spam which was removed and that action put it back to the top of the list. I had answered before I noticed :>D
6/10/2022 9:10:25 PM • Nikon Optics • Answered on Jun 10, 2022
How do I remove water from INSIDE my Nikon A211
Get some industrial size silica gel bags and warm them in the oven. Put a couple of bags inside a large Ziploc bag with the binoculars and leave them in a warm place like an airing cupboard for a week. It there is a lot of water, remove the object lenses (the large end, they should unscrew) and shake the water out. The gel packs last forever and can be dried out in the oven before use. I have some from the mid 1960s as my dad used got them at work from rolls of copper foil that were delivered to make printed circuit board. https://www.amazon.com/large-silica-gel-packets/s?k=large+silica+gel+packets ..
6/10/2022 9:02:12 PM • Nikon Optics • Answered on Jun 10, 2022
I was traveling with the
depends on what they cost. you did not list model or maker.sounds like they can be repaired , lenses have shifted, and has to be realigned. can i help further [email protected]
3/27/2020 9:48:14 AM • Nikon Optics • Answered on Mar 27, 2020
Nikon binoculars ser#AD 002995 10x42. 5.4 degrees need parts?
No thanks, but thank you for thinking of us
7/18/2019 8:58:22 PM • Nikon Optics • Answered on Jul 18, 2019
The I have a Nikon Laser 800 Buckmasters 8 x 28 4.5 " The black exterior surface is dissolving and is all sticky. Is there a cure for the problem?
This YouTube video shows how to clean the lens.
https://youtu.be/p_KImwAxvwk
6/5/2019 9:47:57 PM • Nikon Optics • Answered on Jun 05, 2019
I need a replacement battery cap for my Nikon Rifle Hunter 550, how can I order one
notify nikon or a camera / electronics repair shop online search
12/2/2018 3:52:31 PM • Nikon Optics • Answered on Dec 02, 2018
Is the Nikon Prostaff 3 Rangefinder good for the golfer?
Nikon Prostaff 3 Laser Rangefinder You would obviously expect something superior from Nikon. Well, this renowned company will not disappoint you. They have maintained their expert quality, but that does not make the product expensive. Nikon Laser Rangefinder gives you a crystal-clear image at a very low price. With the launch of Nikon Prostaff 3, two categories of rangefinder seekers have got something to rely on for their ranging needs. Golf players belong to one category while others who want to get top features but maintain a budget belong to another category. Many hobbyists and professionals are getting keen on using rangefinders. It enables hunters and golfers to have a smooth field of view. It gives you enough range and brightness for clear sight. Nikon Prostaff 3 Laser Rangefinder has created some buzz among outdoor lovers. The multicolored display is adequately bright and able to show distances in meters and yards. There is a continuous measurement mode that facilitates multiple measurements without requiring users to make any additional adjustments each time they switch targets. This mode helps users to gauge the accurate distance between particular objects and their current positions. The built-in slope compensation deals with the changes in slope heights almost accurately. Making precise measurements at different angles up to 89 degrees becomes a breeze.
3/17/2018 7:35:25 AM • Nikon Optics • Answered on Mar 17, 2018
What size lens caps for nikon monarch atb 10x42 binoculars
Why not measure the item and find out ?
1/18/2018 6:55:08 PM • Nikon Optics • Answered on Jan 18, 2018
2answers
Hi, tech help with a pair of Nikon binoculars that I have had for sometime now.
We might be able to offer advice if you were to tell us what the actual problem is.
1/10/2018 9:44:00 AM • Nikon Optics • Answered on Jan 10, 2018
I have a pair of
Sounds like internal fungus in the balsam. If it does not affect their use, I should ignore it.
8/20/2017 11:31:50 PM • Nikon Optics • Answered on Aug 20, 2017
Did you have binocular nikon monarch 7 8x42 and how much it cost
They are £399 at Wex Photographic (opposite Asda)
12/7/2016 9:11:56 PM • Nikon Optics • Answered on Dec 07, 2016
I have a savage 110 270 win.i put a nikon buckmasters2 4x12x40 on it im trying to sight in at 50 yards i looked it up it says to sight in at 50 yards it says -0.14 i do not know what that means
The only way to sight in is to bore sight or use a bore sight laser then put rounds down range at the target to get the point of aim and point of impact to converge
12/4/2016 10:45:46 AM • Nikon Optics • Answered on Dec 04, 2016
No one knows about my nikon rangefinder...thought y'all new it all
Ricky, there are hundreds of us, but we're all volunteers. Perhaps your original question wasn't clear enough that we could figure what you wanted out. Please try again, and give us full information about what you want, what's not working the way you want, and the model of your Nikon. We have a hard time guessing all that.
10/30/2015 8:36:38 PM • Nikon Optics • Answered on Oct 30, 2015
Laser 400. Where can I get a battery cover?
Battery Cover Nikon Sale‎
battery-cover-nikon.compare99.com/‎ Up To 70% Off Battery Cover Nikon Battery Cover Nikon
9/30/2015 11:40:14 PM • Nikon Optics • Answered on Sep 30, 2015
2answers
Why do i see a
Because your glasses (prescription or reading) are configured to correct your "far" sighted vision deficiency. Even though the scope is located at a very close distance to your eye, the point your scope is focusing to/at is many? yards in the distance. If you're like many of us, you can see satisfactorily at a distance, but your arms aren't long enough to allow you to read a magazine?
3/29/2015 7:39:58 AM • Nikon Optics • Answered on Mar 29, 2015
Nikon 8426 6-24x50 Monarch Side Focus Rifle Scope Logo
1 questions posted
Top Nikon Optics Experts
john h
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Nikon Optic Expert? Answer questions, earn points and help others
View Most Popular
Nikon Optics
  • Nikon Optics
Most Popular Question
very blury above 10 x no mater ajust
  • Optics
