Mostly only a SMART tv will connect to the internet. The instruction book will tell you more. The presence of an RJ45 socket should indicate possible internet capability.
Some tv top boxes will provide limited internet connectivity for older tv's for the purpose of catch-up tv and internet only tv channels.
Most tv sets can be linked to a desktop or laptop computer to provide full internet coverage on a large screen.
Nov 20, 2013 - Q: Can I connect the TV to the PC via a VGA cable...bearing in mind the .... Forum; SolvedI'm trying to connect my Sony bluray player home ...
Some TV's have to be off before you connect the HDMI cable to the computer. Try connecting the cable that way. Computer on --tv off--connect cable-- turn tv on.
I understand that your TV is turning ON but you're not bale to view the videos on the TV screen. If the TV is connected to a wall outlet through a Surge protector please disconnect the connection through the Surge protector and try connecting the TV to a working wall outlet and check if that helps.
Please check the connection between the TV and the connected device. Please try using a different device and check if that helps. This is to check whether the issue is with the TV or the connected device.
Please try to explain the issue as much as you can next time.
What are the video sources connected to the TV?
Does this issue occur with the TV when connected to other devices?
How did you connect the videos sources to the TV?
Which connection are you using to connect the devices to the TV?
You TV doesn't support 1080p resolution, so please check whether the connected device is giving output in 1080p resolution.
If the issue still persists service of the TV is recommended.
How do I connect direct tv to denon and then get sound If the RCA TV has HDMI input connect as follows: 1.Connect an HDMI cable from the Directv box to an HDMI input on the Denon. 2.Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV 3.Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV. 4.On front of denon press the input mode button to select auto If the RCA TV has Component input (Green,Red,Blue) connect as follows: 5.Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR). 6.Connect a Component Video cable from the Denon to the RCA TV Component Video input. 7.Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8.On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows: 9.Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR). 10.Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11.Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV. On front of denon press the input mode button to select auto
