Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual Logo
Posted on Jul 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When walking without holding onto the side bars it feels like the belt goes forward/slipping at different intervals. How can I adjust the belt for a smoother walk or run?
Electro Med Services
Level 3:
  • Nordic Track Master 6,694 Answers
  • Posted on Jul 29, 2011
Nordic Track Master
Level 3:
Answers
6694
Questions
Helped
1872739
Points
21433
To adjust the treadmill belt just watch the following video. It will help you for the same.
ok
Remove casing to get to belt
Is this an upright? Belt may be accessed by removing the top
cover...only two screws....a great design. Pull up on the brush
bar and remove belt...just make sure you put the correct one back in.
Slip the belt over the motor pulley and onto the brush bar...
pull forward and insert bar into the side slots. Hope this helps.
Regards,
Dennis
1helpful
The walking belt jars when running fast. Also I want to know how to lubricate it. Anyone with a manual? Please help?
Follow the directions below to determine what is slipping. You also can get a copy of your manual by going to iconservice.com and downloading one from the manuals tab. Here are the directions for testing the slipping problem.
* take nail polish or paint and place a mark starting on the front roller pulley and going onto the front roller metal shaft
* then try to walk on it and see if the white mark separates
* if it does then the roller is bad and would need replaced or tap screws placed through the pulley into the metal shaft to hold it in place
* if it doesn't separate then the drive belt is slipping and most likely will need replaced, although you could try spraying belt dressing on it to see if that would be a temporary fix.
* if neither of these is your problem and the walk belt is slipping then you will need to try to adjust the screws in the back of the treadmill through the end caps. these are allen wrench screws.
Tighten each one the same amount such as 1 full turn to start with.
see if you can now walk without it slipping.
If not then tighten 1-2 more turn on both sides.
If after 2-3 full turns it is not tight enough
I would recommend replacing the walk belt.
Hopefully this helps with your problem!
The belt slips slightly. i checked the motor belt and it is okay. I also adjusted the treadmill belt per instructions with about 2"-3" when i slip my hand under it.
My belt skips but the motor is still spinning. it was working fine but now the belt stops when ever I step on it.
The belt has been replaced and is slipping
1helpful
The belt is sliping as I walk or run
Belt skips when weight goes on. It squeaks and
1helpful
The belt moves towards the left when I work on it; it jerks when I ride
1helpful
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
How do I adjust tension on walking belt
A good way to test your walk belt to see if it is slipping is to stand on side rails with treadmill running about 4mph and while holding onto handrails keep one foot on the side rail and put your one foot on the center of the belt in a slight stomping motion,if the belt is loose you will feel it slip. To adjust a loose belt tighten each screw at back of treadmill 1/2 tun each until the slippage goes away. Be sure not to over tighten belt as this will cause excessive wear.If the belt has shifted to one side and you need to center it, go to the side it has shifted to and turn the screw clockwise 1/4 turn at a time until it centers.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
