ASUS M2N-E SLi Motherboard Logo
Posted on Jul 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptops mic is not working - ASUS M2N-E SLi Motherboard
Anonymous
Level 3:
Genius:
  • Master 1,016 Answers
  • Posted on Jul 20, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1016
Questions
0
Helped
413502
Points
3013
Go into the device manger and check that the driver for the mic is still there. If not you will need to download the driver for your model laptop.
Hope this helps.
Thanks
Jason
1helpful
I have an HP Pavillion dv2700 laptop with windows Vista. My mic was working fin until a few weeks ago, now no one can hear me on google voice or skype. I checked the mic settings and it is not muted and...
You can try going into device manager and find the device and remove it then reboot and let it reinstall the mic drivers. If that does not work try going to the HP site and see if a new driver is available and install it. The mic could have gone bad and you may have to buy an external mic.
Thanks for using FixYa
1helpful
How will i know if the mic is working if the laptop is built with mic?
If the mic is present, you can access speech recognition software to check if the MIC is working, to do so: Click Start> Control Panel> Ease Of Access> Speech Recognition Options
2answers
My integrated mic is not working how do i check it
Hai,
Right click on my computer, click properties, press hardware tab, then click device manager. Anything with a ? in yellow means the driver is not installed. Is it a mic thats mounted into the laptop? Or did you connect it? If you connected it, try changing mics and see if that works.
My laptop microphone isnt working
Good day, Hi, to test your laptop mic, open the sound recorder. 1. if you ar using XP, goto START, All Programs, Accessories, Entertaiment, Sound Recorder. If the sound recorder loads normally, press the red button, shout as load as you can, you will see sound waves on the recorder. 2. If the sound recorder does not loads, chances are your mic isn't working properly, Load the device Driver for your mic, you can find the driver on the CD that came with your laptop, if not you may need to go to the Internet to find the MIC driver. 3. If the driver is loaded on your laptop, chances are it may be defective, you have 2 options, 1. replace the mic on your laptop, which requires you to dismantel it, get the defective mic and replace it. 2. just get an external mic. hope this may help.
How can i use headphone's mic on my acer aspire4720z?
there are some ports in the front side of your laptop...try with one headphone with mic....please connect the ports with the cables of the headphone...
I used windos XP BUT NOT WORKING MIC
it may because of your windows XP is not installed properly.....or your MIC have some damage.Try to reinstall it again....or you might need some driver for your MIC.....are you using the embedded MIC or external MIC....?
16helpful
10answers
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. [email protected]
1helpful
2answers
G1 laptop - display and mic problem
OK ya have a bad connection problem, I think the wires that go between the case and screen may be damaged or loose? in any event ya gonna haveta take it to a repair shop :( The Mic problem MAY be inter-related.. however until ya fix the screen this is a moot point, no? The Mic problem is probably just an incompatibility problem... not aLL mic's work on all pc's even when they work on others.. Oh say try a USB mic they are great.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
