Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer.
Thanks for contacting Fixya. Bye for now.
Hi, If you need to re-install the OS (operating system),you have change the boot order in BIOS mode. For that restart the PC & press F1.You can enter into the BIOS. Select DVD drive as first boot device. And press F10 to save settings. Insert a bootable (.iso) Windows CD and restart the PC. After
restarting it'll shows PRESS ANY KEY TO BOOT FROM CD.
OR
You can select an easy method by pressing F12 while booting. It'll shows the boot order, so that you can select the DVD drive.
thanks & regards
Anas K A
