Greetings, I changed out the battery on my expedition and all is well, except the alarm will not sound any more. I have set the beep to be 'on', and the watch does go into alarm at the set time because I see the indiglo light up and the face flashes. However, no beep sound. Any solutions?
Good after noon ! maybe the problem of your watch is wrong possition of case back because the speaker or buzzer of your watch is attached on the case back , so open the watch and fix the case back at the correct possition ,!thank you ! god bless !.....
I had the same problem with mine. I took off the back plate and turned it 180 degrees so the "E" on the back plate is now right-side up when the watch is turned over. The alarm sounded on all 3 alarms. I tested the solution by putting it back on upside-down and the watch's alarm once again did not sound. Then I repeated the fix with the "E" right-side up and the alarm sounded again.
same issue here. Reset the back to make sure it was in the right position and still no sound with anything. I also see the flashing light when timer or alarm goes off.
