SOURCE: Charging a MPV4 hoveround chair
The battery charging connector, which may appear as the female connector of a stage-quality microphone, is underneith the Joystick control arm. An external charger should have been provided by the seller, so if you don;t have one, you'llhave to contact the chir manufacturer.
SOURCE: Hoveround MPV4 Just quit
The Hoveround MPV-4 had 2 different types of battery connectors. The old type had threaded edges that you would plug in, then screw them tight. The new type has a release clip on one side. They switched from the old to the new because of continuity problems such as this. Which type of battery connector do you have?
SOURCE: Hoveround mpv4 does not work led flash when turned
This 8-light code is a joystick controller problem. It is an internal problem with the circuit board located inside the joystick. The entire joystick assembly would need to be replaced in this situation. If you are in need of a joystick, I have several for sale.
SOURCE: where do i go to download the manuel for my
There are no manuals to download.The most information I can find is http://www.usatechguide.org/itemreview.php?itemid=568
i suggest dropping them a email for a manual.
