U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
Posted on Jul 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't enable the UPnP - U.S. Robotics MAXg USR5461 (738168036790) Wireless Router
Steven Wander
Level 3:
  • Master 599 Answers
  • Posted on Jul 18, 2011
Steven Wander
Master
Level 3:
Answers
599
Questions
Helped
286543
Points
1337
Dont need it. Its a security risk anyway. Try and do without it.
I have a dlink 615 and need to disable the UPnP. How do I do that. I cannot get access to the internet because of a security problem with it
in most Routers
Steps to be followed for enable or disable the UPnP:
1. Open a browser and type in http://www.routerlogin.com/ or http://192.168.1.1 or http://192.168.0.1
2. Log in to the router. By default, user name is "admin" and the Password is "password". May differ in your device /settings
3. Click on Advanced.
4. Click on Advanced Setup and then click UPnP.
5. Click the Turn UPnP On box to enable or disable UPnP.
How do enable upnp on belkin router
Since you aren't specific about the model of Belkin router you are using, I can only give you some general advice. This is what is have from MY Belkin router manual. Yours may be different....
Enabling/Disabling UPnP
UPnP (Universal Plug-and-Play) is yet another advanced feature offered by your Belkin Router. It is a technology that offers seamless operation of voice messaging, video messaging, games, and other applications that are UPnP-compliant. Some applications require the Router's firewall to be configured in a specific way to operate properly. This usually requires opening TCP and UDP ports. An application that is UPnP-compliant has the ability to communicate with the Router, basically "telling" the Router which way it needs the firewall configured. The Router ships with the UPnP feature disabled. If you are using any applications that are UPnP-compliant, and wish to take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "System Settings" page. Click "Apply Changes" to save the change.
How do I enable UPnP on a Smart RG SR350N router
UPnP ports are sever security hazards so they are disabled by just about anything that has anything to do with security. The router might not be the problem; you might have to enable it in the network security software and on the individual devices involved as well.
MY upnp on the router is enable but when i do connection test on the playstation it says that upnp is not avaible. can you help me
Once you have enabled UPNP on your router and saved the change, restart your router and your PS3, then try. That should get them on the same page and the PS3 to read that UPNP is enabled.
1helpful
How do i enable upnp
Using your Internet browser, you can access the Router's Web-Based Advanced User Interface. In your browser, type "192.168.2.1" (do not type in anything else such as "http://" or "www"). Then press the "Enter" key.
Click login, the router comes with no password set, so unless you have changed the password, just click login.
To take advantage of the UPnP features, you can enable the UPnP feature. Simply select "Enable" in the "UPnP Enabling" section of the "Utilities" page. Click "Apply Changes" to save the change.
Linksys wrt54gs changing upnp settings
Hi, you can enable UPnP on a Linksys WRT54GS router by logging in and then clicking on the Administration tab. The first sub-tab is Management, and at the bottom of that page there are buttons to enable or disable UPnP. Click Enable and then click Save Settings at the bottom of the screen.
2helpful
Enabling uPnP
Open the RSP by typing 192.168.2.1 On the Address bar of the internet Explorer
On the left side under utilities Click System Settings
you can Enable UPnP in this Page
1helpful
How do I enable UPnP on a router
Login to the router throught your chosen web browser, then on the administration tab at the top tick the box that enables UPnP
"UPnP. If you want to use UPnP, keep the default setting, Enabled. Otherwise, select Disabled.
Allow Users to Configure. Keep the default setting, Enabled, if you want to be able to make manual changes to
the Router while using the UPnP feature. Otherwise, select Disabled."
1helpful
UPnP?
This FAQ is for the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624S, DI-714P+, DI-754, DI-764, DI-774, DI-784, DI-804HV, and DI-808HV. Universal Plug and Play (UPnP) allows discovery of UPnP enabled devices in a network environment. UPnP is only available on Windows Me and XP. If you are not using either operating system on any of your computers, or do not want to use UPnP, then it is recommended to disable UPnP on the router. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Tools tab then click Misc. to the left. Step 4 Under the UPnP Settings section, select Enabled using the radio buttons to enable UPnP on the wireless router, or select Disabled using the radio buttons to disable it. Step 5 Click Apply and then click Continue to save the new settings.
6helpful
2answers
How do I configure UPnP? on my router?
Top U.S. Robotics Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
