From Page 15 of the Manual:
Press and hold the "Custom Broil" pad for 5
seconds. A short tone will sound
NOTE: The temperature display will go off
and the temperatures displayed will
after a conversion. The temperature display
be converted. To switch back to "F, repeat the instructions above.
NOTE: The temperature display will go off after a conversion.The temperature display will reappear the next time you press a cook function command pad.
To display temperatures in "C instead of OF:
Press and hold the Custom Broil pad for 5
Broiling
NOTE:
The text got jumbled. here is the corrected text:
Press and hold the "custom Broil pad for 5 seconds. A short tone will sound and the temperature displayed will be converted. to switch back to degrees F, repeat the instructions above.
Note: The temperature display will go off after a conversion. The temperature display will reappear the next time you press a cook function command pad.
Sorry for the mixup. Good luck!
