Never seen that error. Try to remove the batteries and hold down the on button for a few seconds. Reinstall the batteries and turn on. If the error comes up again, give Triton a call.
Special Calibration- If the display shows [OUE2] after turning on: 1. Turn OFF the scale. 2. Press ON/OFF key briefly then immediatley press and hold the MODE and TARE buttons simultaneously until [CAL] is displayed. Release the MODE and TARE buttons and a random internal statement number will be displayed. 3. Press the MODE key once and the display will show [2Ero]. 4. Place a 200g weight on the center of the platform. Wait 2 seconds then press MODE key again. The LCD will display [PASS] then [200.0]. 5. Remove the weight and turn off the scale. Special Calibration is complete.
its not compatible does not have the drivers to activate the device to read info. the driver file on the device has to be read before drivers can be use to read device.
The problem with your magellan triton is that there is a file missing in the support file that allows the triton come on properly hereby leading it to jam.
The solution is for you to get your triton connected to a computer, then you back up the software on the computer, format the triton then you restore the software and maps on the triton. Then your triton will be in good condition once again.
Hope this information helped.
This problem is caused by a corrupted software file on the internal memory. The chip has to be reflashed. If under warranty return the unit to Magellan.
5 Ohms at the rotor.
Disconnect all the stator wires and measure each one to ground, it should read opened.
Before disconnecting wires, mark which are hot and which are neutral. Measure between the hot neutral wires and some should read at least 0.5 ohms. You should have T1 and T2 reading 0.5 and T3 and T4 reading 0.5. T1 and T3 should read opened, T1 to T4 should read opened. Also, T2 to T3 should be opened and T2 to T4 opened.
