SOURCE: breaker keeps tripping
If the breaker itself is more than 15 years old, replace it. If it continues to switch off, check the amp draw of both the inside and outside unit.
SOURCE: Panasonic Flat Screen Model No. CT36HX42F won't turn on
the 2SC5612 transistor near the fly back transformer is shorted
SOURCE: JVM239WV001 Stopped working.
It could be a flame sensor, which is a thermal switch located inside the cabinet on top of the cavity (there may be two of them). One power lead should go to the fuse, the other would go to the flame sensor. Remove the flame sensor and check for continuity. If it shows open (infinite resistance), put it in the coldest part of your freezer for a few minutes, then retest. If it now reads continuity (zero resistance), replace it, put the appliance back together, and see if it works.
Yes you should try replacing the run capacitor.
SOURCE: Homelite xl-175 chain saw no prime
As long as the line fits tight so its not sucking air you should be ok.. try changing out the plug if its old. Clean out the air filter too.. But the line should be ok as long as its tight..
