E-Machines eMachines Desktop PC Logo
Anonymous Posted on Jul 10, 2011
I took the front off the e machine w2888 desktop but did not notice the three wires was not one plug, what order and colored wire up or down. Their is a pwr led, pwr s/w, hdd led wire. Thanks Jerry
joecoolvette
Level 3:
  • E-Machines Master 5,660 Answers
  • Posted on Jul 11, 2011
joecoolvette
E-Machines Master
Level 3:
Answers
5660
Questions
0
Helped
2194829
Points
18014
The eMachines W2888 uses an Intel D845GVSR motherboard.
This is the download page for the Intel D845GVSR motherboard manual, (Product Guide),
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Left-click on the first file name in blue -
Intel Desktop Board D845GVSR - Product Guide (PDF)
This is a PDF file. The computer you are using has Adobe Reader on it, which uses PDF files.
After you click on the above file name it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
[ Took 4 seconds to see the first page come up, just now. File was fully downloaded ]
At the top of the PDF file is the page number box. It is to the right of the blue Down Arrow.
This is the page number I will be referring to, and may not be the actual page number of the manual.
Go to Page 11.
This shows an illustration of the motherboard looking down at it from the top.
The letter S points to the Front Panel header.
[The plastic front of your computer is the Front Panel.
The area of pins on the motherboard that the cables (Wires) go to from the Front Panel, is the Front Panel header ]
Looking at the motherboard with the Processor to the top, Ram memory slots to the right, and the white PCI slots (3) to the bottom, the Front Panel header is located parallel to the bottom right edge of the motherboard.
(The illustration has the motherboard sitting on it's right side.
Not the direction it is sitting in your computer.
In your computer the motherboard is sitting as described above )
Now I would like you to go to Page 31.
This illustration shows the various internal headers on the motherboard.
The letter C points to the Front Panel header. (J9G1)
Note that the pins in the Front Panel header are labeled with numbers.
(Pinout)
There are 4 pins across the top.
There are 5 pins across the bottom.
Starting from the Left side of the motherboard, going towards the right, across the Top of the Front Panel header;
Pins 2, 4, 6, and 8.
Starting from the Left side of the motherboard, going towards the right, across the Bottom of the Front Panel header;
Pins 1, 3, 5, 7, and 9
Page 32: Front Panel Header
A) Pins 1 and 3 are for the HarDDrive activity LED light. (HDD LED)
Pin 1 is for the Positive ( + ) wire.
If the LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF used.
Pin 5 is for the Ground ( - ) wire.
C) Pin 9 is for a 5 Volt wire. (It's probably Red in color, IF used)
D) Pins 2 and 4 are for the Power On LED light. (Light Emitting Diode)
E) Pins 6 and 8 are for the Power On switch. (The Power On switch is located inside the plastic Power On button assembly)
F) Pin is N/C. Not Connected.
For additional questions please post in a Comment.
Regards,
joecoolvette
  • joecoolvette
    joecoolvette Jul 17, 2011
    Haven't heard from you scottszar. Posted to see if this solution fixed your problem.
I have purchased a Thermaltake V3 black case and am trying to install my M2N68-LA motherboard. The motherboard has a combined 9 pin header for power switch, power l.e.d. and hdd l.e.d. which was one plug...
1) The 9-pin header you are referring to, is the Front Panel header.
(Processor to the top, Ram Memory slots to the right, the Front Panel header is at the bottom right corner on the motherboard)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00906129&lc=en&cc=de&dlc=&product=3397528
The plastic piece on the front of your computer is the Front Panel.
(Sometimes referred to as a Bezel)
Make a drawing, and notes as to where the individual wires go from that Front Panel header plug, (One-piece plug), to the Front Panel.
Follow the wires from the plug to the Front Panel.
Mark down where Each wire goes.
You may have to take components off of the Front Panel, in order to see exactly where Each wire goes.
For example:
You may have to remove the Power On button/switch assembly from the Front Panel.
It may have the Power On LED light, Power On button, (Switch), and perhaps the HarDDrive LED activity light, in this assembly.
The wires are color coded.
Generally, but not always, when two wires are used in conjunction with each other, (Example, Power On switch, or Power On LED light), the wires will be twisted together.
One wires insulation may be of a solid color, and the other wire may be white, with a stripe in the color of the solid wire.
Example: Wire with Red color, and wire twisted with it may be White, with a Red stripe.
See if these two wires go to the Power On switch.
End of example.
Follow each twisted pair of wires back down to the Front Panel header plug.
(One-piece plug)
See which socket holes the individual wires go to.
Mark it down in your drawing, and notes.
Mark where the individual socket holes plug onto each pin, in that Front Panel header. (9-pin header)
When you are finished, you will have a pinout for the Front Panel header on the Asus M2N68-LA motherboard, and will know where the individual wires go from your ThermalTake V3 computer case.
For the LED lights there is a Positive pin, ( + ), and a Ground pin. (Power On LED, and Harddrive activity LED, for example)
(Ground. Also referred to as the Negative pin. ( - )
This is DC Voltage)
If you have the polarity backwards, (Positive wire of the LED light is going to the Ground pin, Ground wire of the LED light is going to the Positive pin), the LED light will be dim.
(When operating)
Switch the wires around.
If you have questions, or need clarification of what I have stated above, simply state in a Comment.
(Believe upper right of your page)
Wiring conia ccd4501
There could be two situations for you. For the wall outlet, you may have a four prong plug or a three prong plug. For a three prong plug the outlet has three prongs and the terminals inside match up with these prongs. The two slanted prongs on the top are the hot terminals and the red and black wires get connected to these (order doesn't matter but keep the wires matched up with the terminals on the same sides). The white wire is connected to the "L" shaped prong, the third lower prong. The bare copper wire is just bent out of the way. At the dryer for the three prong there will be three terminals 2 hot and one neutral. Usually, your dryer cord will have the neutral as the middle wire, but pay attention if your cord wires are color coded (where white will be your neutral wire). At the dryer there is a terminal which is connected to the frame of the dryer by a piece of metal. This is your neutral, connect your neutral wire from your cord up to this. The other two wires get connected to the other two terminals (order doesn't matter but keep the wires matched up with the terminals on the same sides). For the four prong its very similar but there is a small change, that bare copper wire is now used. The terminals on the wall outlet will line up with the prongs. The two vertical terminals on the left and right are your red and black wires. The "L" shaped prong is your white wire. Now the fourth prong, the one shaped like a semi circle is the terminal you connect that bare copper wire up to that is your ground. At the dryer for the cord (If its a four prong cord your wires should definitely be color coded). The terminal that had a connection to the dryer frame now will no longer have one. The terminal thats connected to the frame you connect the green wire to. The terminal that was connected to the "green wire terminal' is now the neutral terminal and your white wire gets connected to it. The other two terminals are where your connect your last two wires.
May 10, 2010 • Dryers
Problems putting which wire where
mouse and keyboard are color (purple and green) coded monitor is serial port only fits on one place and screws on! Power plug is at top has three slots in cord! It hard to plug things in wrong! plug um all in and turn it on!!
New PSU installed, but still wont turn on.
Doesn't it come with a manual?
If you lost it check the internet for a copy of it.
1helpful
Convert three pin plug to four pin
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
2helpful
Emachines W2888 not turning on
Easy fix! Sounds like you bought a bad Power supply. Purchase an identical p.supply and it will run like a car!
1helpful
2answers
Rca hd61lpw165 color wheel replace
Remove speaker grill at bottom of set. Remove screen by taking out all the screws from the back of the rim of the screen. Two ribbon cables from the front controls need to be unplugged to set the screen to one side. Remove two screws holding the light engine shroud in place. Side it toward the front and lift out of the way. The color wheel housing as only two screws holding it down. There are two wires coming from the color wheel housing. One has three wires with a white plug on the end that plugs into the left end of the light engine's metal box. Next to the plug is a ribbon cable that is slid into its socket. You will notice two shiney philips screws holding down the color wheel housing. Remove them and the color wheel housing can be lifted out. Unplug the two wires going to the light engine.
5helpful
Emachine W3400/ front panel connections
they have to be plugged in horizontally although it is possible to plug them in vertically because the pins are evenly spaced either way. they are color coded just not like you would expect for example one plug has a green wire and a white wire the green side goes to the green pin and the white side goes to a green pin with a white cross you have to look close because there are several green pins which is what threw me off do this with all three plugs
Washing machine probs
right you have 2 parts for heating the water you have the heater element you can test this simply by undoing the wires making sure to wright down order they go in get an old wire with a plug on the end attach each colour in the order you took the proper wires of plug it in if the element is working then you will feel the heat and see it glow if it doesnt then its a faulty element if it does then it will be your thermostats both element and thermostats are located at the front behind the front panel this needs taking off
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
