Boss Micro BR Digital Recorder Logo
Posted on Dec 02, 2017
Boss BR900CD External MIDI
I am trying to mix music from an external CD player with voice from a connected microphone on a Boss BR900. I can get the CD player music in using the MIDI input, but I cannot seem to get both the CD music and the external microphone inputs to work at the same time. This seems like a simple task. Can someone help?
Howard Bailey
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 6 Answers
  • Posted on Dec 17, 2017
Howard Bailey
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
6
Questions
0
Helped
2544
Points
6
I'm not totally familiar with that Boss Digital Audio Workstation but it sounds like what you want to do is record both the music and vocal track at the same time. If that's the case I believe you can push both "Line" and "Mic" input buttons (perhaps not exactly named as such) at the same time to record both simultaneously. Otherwise I would suggest copying the music to it's own stereo track (or two individual tracks, each panned opposite from one another to maintain stereo) and then record your vocal track separately. That way you can record several takes and edit down the best parts to one final track.
I hope that helps.
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Dec 24, 2008
SOURCE: Trying to find operating manual or help using a Boss Micro BR 4
Greetings I think you can download the requested operating manuel here: http://www.lifeismusic.co.uk/Products/video/manuals%20and%20specs/boss/microbr_om.pdf
Kind regards Fred.
Anonymous
  • 109 Answers
  • Posted on Oct 09, 2009
SOURCE: BOSS DD3 STAYS ON AND WILL NOT TURN OFF
It's supposed to do that. An extra lug on the input jack is connected to the battery and/or power supply's ground.
So the only way to power off any pedal is to disconnect the input jack. If you use a power supply and power multiple pedals you can simply disconnect the power supply to cut power and avoid unplugging each one.
Michial Gueffroy
  • 1140 Answers
  • Posted on Feb 03, 2010
SOURCE: How do i transfer music from my Computer to my
Page 2 of the Turbostart manual explains that in some versions of Windows the Micro BR may appear as a removable storage device titled "Removable disk (?:)." The manual is here:http://cms.rolandus.com/assets/media/pdf/MICROBRts.pdf It also mentions free downloadable wave converter software. Hope this helps.
Anonymous
  • 9 Answers
  • Posted on Dec 14, 2010
SOURCE: Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
The beats you have programmed into the drum machine will not play through the midi cable. In order to do what you want you need to connect the audio output from the drum machine to the audio input of the br-1180. What you should then do is connect the MIDI out of the the br1180 to the midi in of the Dr5. This will allow you to start and stop the drum machine with the play button on the br1180. MIDI can be a complicated thing so be sure to RTFM about MIDI for both of your BOSS devices to understand what they can do to work together. Good Luck
Anonymous
  • 6 Answers
  • Posted on Jan 15, 2011
SOURCE: Hey i just got a
Troubleshoot. Try different cables, mics, instruments, etc to make sure that its the device and not something else.
Make sure you don't have any digital effects (compressors, guitar effect simulators, etc) activited.
See if there's a way to restore the device back to factory settings. Make sure you backup your recordings first.
Can two d3200 recorders connected and record 24 tracks simultaneously
I will assume you want to sync the two as one. I have one of these sitting in a closet. The 3200 will record 12 tracks at a time if I remember correctly. I believe the Korg will sync to Midi Time code. I just wonder if the midi implementation allows for start and stop code. Anyway, I found this information:
x2. MIDI messages used by the D3200 Note On (Note, velocity), aftertouch, pitch-bend:
The D3200 uses these messages to control effects.
Program change:
The D3200 uses these messages to switch scenes.
Control change:
The D3200 uses these messages to control mixer and
effect parameters.
MMC (MIDI Machine Control):
MMC messages can be transmitted from the D3200 to control an external MMC-compatible sequencer or recorder. MMC messages received from an external sequencer or recorder can be used to control the D3200.
MTC (MIDI Time Code):
The D3200 can transmit or receive MTC messages to
synchronize with an external sequencer or recorder.
MIDI Clock:
The D3200 can transmit MIDI Clock. It can also receive MIDI Clock if you have selected MIDI Clock for the tempo track and are recording the tempo track.
Jul 04, 2019 • Korg Music
How to connect Gk3 equipped guitar to Electric Piano or Synthesiser ?
A Gk3 cannot be connected directly to an electric piano or synthesiser. The 23 pin DIN connector connects the GK3 / GUITAR to a Roland guitar synthesiser which produces the synth tones . This unit can be connected via midi cable to any external keyboard or synthesiser...to produce different or varied tones from the external synth ........provided the devices are able to communicate with each other...see the midi implementation charts for each device for information....
2answers
How can i transfer music to my laptap using usb cable
There is a complete section about this in the user manual, starting on page 161.
http://roland.com/support/article/?q=downloads&p=BR-900CD
Downloaded version 2 to my br900cd now one of my flashcards that i had several songs on will not load message saying unsupported card
Don't you just hate these incompatibility issues?
Try the VSPLANET.com site where a lot is discussed about the Roland (Boss) recorders.
Where do I download midi keyboard drivers for a technics keyboard.
Normally the drivers you load are for the MIDI interface you use, not the keyboard.
The software for the keyboards are usually either system update programs OR editors for the voices, etc. There are many music editor programs and most have some method of communicating via MIDI to external devices.
Apr 22, 2010 • Music
2answers
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
1helpful
Yamaha 61 key keyboard midi usb connected but what next
Depending on what you want to do...
If it's only music Mixing, you will have to plug your keyboard via audio jack to the line in of your computer. Then Audacity (free soft) can do the job.
If you want to edit midi file with your keybord you will need midi editor software like Linux-Rosegarden or if under windows try LMMS (all free soft of course).
Good luck
Top Boss Music Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a Boss Music Expert? Answer questions, earn points and help others
