20 Most Recent
Boss TU3 Tuner Questions & Answers
BOSS TU-3 Tuner will not work with power supply or battery
It was probably connected backwards in polarity from a power supply which burnt a diode. These things have backwards polarity of 9v adapters which means positive on the outside of the plug and ground in the middle, unless you have the original boss power supply.If you have a generic power supply, cut the plug off and switch the wires and try it.
Dropped boss TU-3 tuner
Time to download a tuner app to your phone. Tuners can be fragile and it may not be worth fixing if it's not functioning after a hit or jolt.
Hi, sometimes, when I try
Could be the level from your guitar is too high OR low. Too low the tuner can't get reliable signal... Too high and the tuner will see harmics of the strings. Make sure you set onboard shape or EQ's flat. You CANNOT tune while playing CHORDS... A single note at a time please...
Best sound for dsl15h and MT-2
To achieve a tone similar to Synyster Gates' A7X sound, you may want to start with the following settings:
Green channel:
- Bass: 5-7
- Mid: 2-4
- Treble: 5-7
- Presence: 5-7
- Gain: 7-8
Red channel:
- Bass: 3-5
- Mid: 3-5
- Treble: 5-7
- Presence: 5-7
- Gain: 8-10
When using the Boss MT-2 pedal, set the tone control to around 12 o'clock and the level to taste. This should give you a good starting point for a heavy metal tone.
It's important to note that these settings are just a starting point, and you may need to tweak them to suit your own personal taste, playing style and the room you're playing in.
Keep in mind that the MX112 cab will also affect the sound,so you may need to play with the eq settings on the head and the pedal to achieve the sound you are looking for.
Also, keep in mind that the sound of the DSL15H head with the MX112 cab will be different than the sound that Synyster Gates gets with his rig. However, the settings above should help you achieve a similar overall tone.
1/29/2023 4:52:24 AM •
Boss Music
Answered
on Jan 29, 2023
MG50CFX. Why is fx loop almost silent?
Loaded with a custom 12" speaker, the MG50CFX delivers that iconic ... Take control of your tone with a range of digital FX and four footswitchable channels. ... also has a dual function headphone socket for silent practice or silent recording. ... Effects. Reverb, Phaser, Flanger, Delay, Chorus. Effects loop.
for more visit
https://travismoviereviews.blogspot.com/2021/04/in-earth.html
5/2/2021 6:15:28 AM •
Boss Music
Answered
on May 02, 2021
BOSS ME 70
A multi-effects unit that's as easy as a stompbox - that's the beauty of the new ME-70. The friendly, knob-laden design makes tone creation a snap, but with a powerful COSM AMP section derived from the GT-10, the ME-70 takes the "EZ effects" concept to new heights.
5/22/2020 1:57:47 PM •
Boss Music
Answered
on May 22, 2020
