Tip & How-To about Computers & Internet
PDF Download converts the page all while retaining the page layout, fonts,
images and hyperlinks on the page. Its support for HTML, XHTML and CSS-based
pages ensures the creation of high-quality PDF files, which are ideal for
archiving, printing, sharing and emailing like PDF converter
Mac.
1. Easy PDF
This Converter is used to convert from PDF
file to Doc file. It is independent application software that does not require
the MS Word or the Acrobat Reader. This program allows you to convert PDF file
into Word document with a high speed. You can convert batches of PDFs to Doc
format at one time. It has user friendly interface that makes it easy for use.
Easy PDF has some salient features as follows:
a. It compresses the pdf
file as per your requirement without making changes in content and layout.
b. You can either add or delete text or images from the resultant Word
document.
c. It works well on all the platforms like Win98, Win 2000, Win XP
and Windows 7.
2. ISTS Office PDF Converter
This Converter can convert
word file, excel sheet and image to PDF and can also create images from your
existing PDF file without affecting the privacy and security of PDF files.
3. PDF Converter Elite
If you want to get best result
with low cost and high speed, then you can opt the PDF Converter Elite. Using
this tool, you will able to convert and edit the existing PDF. Not only this,
you can even create new PDF from the older one. It is different from others in
some aspects like it helps in creating new PDF and edit them as well. You can
extract the pictures and text from the PDF files and export to your desired file
format like Word document, Excel sheet or Power point presentation. Moreover,
you can create compatible PDF files that can be easily viewed.
4. PrimoPDF
This Converter by Nitro PDF Software is a
freeware and you can download it from the Nitro Pro Website and install in your
computer system. With this, you can even create PDFs from any file format which
you can use for printing, screening, use in ebook etc.
5. Cute PDF
It is also a freeware that can supports both
for 64-bit Windows XP ,and 32-bit and 64-bit Windows Vista.
