Blaupunkt:
- Press the (PWR) to turn the unit off.
- Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.
- Press both buttons again from more than 2 seconds to cancel this mode.
or
- Try pressing and holding menu for 10 seconds to turn it off.
Bose:
- Unplug the unit and wait ten seconds.
- Plug it back it and press repeatedly on the eject button.
- The demo disc will eject.
Clarion:
- Press and hold the "D" button to enter the settings menu.
- Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".
- Press the "D" button to exit the settings menu.
Garmin:
- DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.
- When the software version window come up, hit ENTER.
- Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.
- The system should reset, when asked to use RETAIL mode say NO.
JVC:
- Hold down the SEL button for 2-3 seconds.
- Use the << or >> buttons to find DEMO.
- Turn the VOLUME knob until it says OFF or DEMO OFF.
- Press SEL again.
Kenwood:
- Go into standby mode, hit menu and then press "hold". A menu should pop up.
- Use knob to select demo.
- Press in on the knob and hold until it says "demo OFF".
or
- Switch to Standby.
- While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.
- Demo mode should now be off.
Magnavox:
- Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.
Pioneer:
- Turn the vehicle's key to the Accessory or ACC position.
- Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.
- Locate the "Volume/Mute" button, located on the left-side of the unit.
- Press and hold the "Volume/Mute" button until the demo mode turns off.
or
- Turn the radio off.
- Push "Memory 5" or "Memory 6" (depending on your model) for just a second.
- When you hear a beep, demo mode is off.
Pioneer Premier:
- With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.
Sharp:
- When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.
- The demonstration mode will be cancelled and the display will disappear.
Sony:
- Press display twice to turn off Demo mode.
or
- Press and hold the select button.
- Press the select button repeatedly until the desired item appears.
- Rotate the control dial to select the setting DEMO.
- Rotate the control dial to select the setting DEMO-OFF.
or
- Press the STOP and the EJECT buttons simultaneously for 5 seconds.
- UNLOCKED should now appear in the display and you should be able to eject the disc.
If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
