Drills Logo
Posted on Jun 19, 2011
I have a B&D Firestorm 18v 1-hour battery charger, model 5100235-09 (240v). When I insert a battery to charge, only the green "battery full" LED lights immediately. But the battery never charges. Opening the charger revealed that the R2 resistor (looks like around 2 watt type, ie. not as big as a 5W rectangular type, but more than 3 times the size of a 1W cylindrical one) has overheated/scorched. I cannot make out the colour bands due to the discolouration, but the first band appears to be brown, second white, third grey?, fourth silver? Does anyone know what this resistor's correct value is supposed to be? Also, diode ZD2 appears to have conduction in both directions, whereas ZD1 does not. Does anyone know what type of diode ZD2 is? Rectifier diodes D1 - D5 all appear OK. Do you know what the T- and T+ connections are for? Does anyone have a circuit diagram for this board? I do not wish to purchase another B&D charger as I have been reading that they are !@#$. I would prefer to try to repair it or, preferably, adapt a DeWalt 18V charger to charge my slide-on batteries. Any ideas on how I can do this perhaps? Cheers
Lance Geoffrey King
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 21 Answers
  • Posted on May 09, 2013
Lance Geoffrey King
Contributor
Level 1:
New Friend:
Cheetah:
Answers
21
Questions
0
Helped
4653
Points
60
Hi I have same problem with the charger. Solution is to replace the charge with new part number issued from B&D Australia
Number of 90515050-01 until stock runs out , then it is replaced by part number of 90578873 early to mid june 2013.
Hope this helps
Lance from Perth , Western Australia.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 24, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2498
Points
I've the same problem with the charger. first the transformer keep overheating and burnt then only the red light will turn on even the battery is fully charged. The F188 cordless drill is one of the best drill B&D has ever made but let down by this poorly designed charger. The rest B&D are just S*#T!I don't have all the answers to your questions:
1. I removed the transformer and replaced it with a external switching mode 24VDC PS.2. R2 is measured around 38 ohms, the colour seems orange-white-black. it does have discolouration. a higher one or two in parallel may help.3. ZD2 is 2V4, and ZD1 is 6V2, that may explain why ZD2 is measured 1.88 V reverse voltage with my Fluke 189. I'll try to use a different value later.4. T- and T+ are for detecting whether the battery is inserted and battery case temperature, there is a tiny temp sensor built in the underneath the metal button, my one measured around 8.8k ohms connected or not. What's yours value?
Why is the green light blinking on the Ryobi charger with the battery in it
My Ryobi 18V One+ charger blinks green while it's charging. When the battery is fully charged, the LED goes to a solid green. However, one battery recently had a faulty cell. After several hours on the charger, the green and red LEDs both were blinking. That indicated that the battery failed late in the charging sequence. It didn't fail the initial testing by the charger. The other battery I charged that day charged fine.
The extended capacity batteries can take 12 hours to charge in my experience. The regular batteries take less time. The charge time will depend on the battery chemistry(The older NiCd batteries take longer to charge then the Lithium batteries.)
I hope this helps. Assuming you aren't dealing with a cold or hot battery or charging environment, if you have any suspicion about a faulty battery, replace it.
(Note: I have a 12V drill as well. Those batteries takes longer to charge for the same relative capacity than the 18V NiCd batteries.)
1helpful
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
6helpful
4answers
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
2helpful
2answers
Top Black & Decker Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
