This is possible. It requires firmware upgrade to disable the FM radio. Follow the directions below link:
http://kb.sandisk.com/app/answers/detail/a_id/5224/~/removing-the-fm-radio-feature-from-the-sansa-clip%2Fclip%2B%2Ffuze-player
Good luck.
Yes, it means it is version 1. Open the Player's drive in "MY computer" and you will see the root directory folder.....
Did you run the upgrade on your player after dragging the file to root directly?
I mean root directory... It is a folder in your player. If the file is kept in the "root directory" folder, the player should detect the upgrade...
SOURCE: FM radio on Sansa Clip does not work
Have you muted the radio by mistake.If you have there will be a square symbol under the FM sign.Press the top of the ring.
No. the mp3 works great. i want to disable the fm radio so that it can not be used. can you help me?
hello i paid $9 for you to answer my question how to do it and you have not. if you don't know how i will get s/o else to help me.
yes, i did not get my problem solved. i would like to disable the fm radio on my sansa clip 4 gb.
my version is v01.02.16a does that mean it is version 1 also what does it mean to drag it to the root directory?
i did all that and i still have the fm radio on the device.
i did check for upgrades and there were none i am not sure what you mean by Root?
i dont know, i did everything and the fm radio still comes up on the unit and plays. anything elso to ck?
i have not been able to disable it. something is not accurate. the mp3 is brand new and it should work. i would like to either get a refund or someone else to help me.
