Compaq AlphaStation XP1000 PC Desktop Logo
Posted on Jun 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am running Unix Tru64 5.0 on Compaq Alphastation XP1000. The computer does not boot and does not display anything and does not beep. The power supply works and some LEDs are on on the logic board and the CPU and chips become hot. Replacing the VGA card did not help.
Anonymous
Level 3:
  • Master 336 Answers
  • Posted on Jun 18, 2011
Anonymous
Master
Level 3:
Answers
336
Questions
0
Helped
82039
Points
1066
Hi.first pull-out your motherboard in the CPU case then power on without memory only processor installed.if you hear continuous beeping your motherboard is working good.
try this beep code means.
No beep means short,no power,bad CPU,loose peripherals.
One beep means everything is normal running motherboard.
Two beep means CMOS error IC.
One long beep,one short beep means motherboard problem.
One long beep,two short beeps means video card problem.
Three long beeps means keyboard error.
Repeated long beeps means memory error.
Continuous hi-lo beeps means CPU overheating.
Hope can help you.
My computer turns on by itself and does not display anything
disconnect the power adapter and battery
2) make a HARD RESET 3) press the button power and hold by 60 seconds.
3) connect the power adapt +battery and try again.
4) if the problem persist. test the power adapter for short and repair or replace.
restart pressing the f8 and go safe mode with network, and RUN the scannow.
5) Run the software coming with the computer.too
God bless you
Compaq gc668aar will not startup_startup repair will not fix
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3436819
It isn't a Processor problem
(Or is there a series of beeps, and the fan is running wide open?)
[ Just curious. Call it a poll, if you will.....
Did you follow Anti-Static Precautions, and did you Thoroughly clean the Processor, and bottom the Heatsink; plus correctly apply, fresh new Thermal Paste? Reply in a Comment ]
Where did you get the Start-Up repair from?
What does the router have to do with this?
Do you get any BIOS Beep Codes?
You have another 'Compaq processor'.
Do you have another KNOWN to be good, Compatible Power Supply also?
Post back in a Comment
Regards,
joecoolvette
(Computer turns on does not = Boot.
When the computer boots it means Windows is running.
Power Supply turns on is also mistaken for computer turns on.
No it didn't. The Power Supply turned on, is all,
http://en.wikipedia.org/wiki/Booting )
1helpful
I'm having problems with my compaq sr5000 desktop.
Is there any message that appears when you turn the computer on? Does anything post to the monitor during the boot process? Normally if the Video Card goes bad and the monitor works you will get a No Signal message on the Monitor. So you are so sure the monitor works, huh?
Since you went inside the computer check and make sure you pushed the Video Card (where the monitor plugs into the back of the computer) into the slot all the way.
Maybe your Power Supply is not working. When you press the power button do the fans start running and you hear the disk drive spinning? Just because you see a light at the the power button or on the motherboard does not mean the Power Supply is working correctly. I just changed one that did that.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.You didn't by chance remove the Heat Sink and CPU while you were removing the fan did you? If you did, you probably need to apply a fresh coat of Thermal Past between the Heat Sink and CPU.
1helpful
3answers
Won't boot. Series of Beeps plus red light
If nothing was displayed on the monitor during the beeps then change the RAM stick(s)
Thanks
Pc cannot boot only displays a blue screen
hey just follow the link
here you will get
Compaq Professional Workstation XP1000 ROMPaq
http://www.soft32.com/Download/Free/Compaq_Professional_Workstation_XP1000_ROMPaq/4-170232-1.html
Compaq Presario V2000 boots up, but
Getting into Windows Safe Mode Users who may not be able to boot into normal mode or are not able to ... "F8 Key.
Linux and UNIX pg command help |/pattern/, Start up at the first line containing the regular expression pattern. filename, A path name of a text file to be displayed.
LS-120 SuperDisk drive help Next, connect the power and boot the computer and install the software ... as the computer beeps or pressing and holding CTRL as the computer is booting up.
Theses site should get ya back on line. Read and follow instructions.
Merry Christmas, Good Luck...Please dont for get to Vote/Thank You.
Merry Christmas
When i turn the laptop on it won't go pass the f1 to resume f10 to restart
Computer BIOS information and help If the computer does not pass the POST, you will receive a combination of beeps indicating ... CH000301, Prompt to press F1/F2 each time computer boots.
Linux and UNIX cut command help Lines with no field delimiters will be passed through intact .
Good Luck please dont for get to Vote/Thank You.
2answers
Troubleshooting
are u getting any beep message ? let me know the model and the beep tone that you get, if you don't get any beep try changing ram if you have VGA card installed try changing that.
7helpful
8answers
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
StorStation fails to boot up - blue screen of death
The beeping alarm could have been overheating. You could try taking the HDD out and putting it in a workstation to run chkdsk on it. Incidently what operating system does this model use? I have an FSV-E1 which seems to run some Unix type system.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
