Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
Posted on Jan 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Frigidaire dishwasher that is beginning to leak from the bottom. After taking off the lower front floor panel and looking under the unit, then pouring a bowl of water into the washer the water drips through unit onto the floor. What do you recommend? This is still an attractive dishwasher.
Phillip Cushnie
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Mar 15, 2019
Phillip Cushnie
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
1215
Points
12
I have seen leaks from around the heating element nuts .
deton8 von Splosion
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Frigidaire Master 3,342 Answers
  • Posted on Jan 14, 2018
deton8 von Splosion
Frigidaire Master
Level 3:
Answers
3342
Questions
6
Helped
928895
Points
54123
Hello Mileshjr,
I don't disagree... Nice looking unit...
What you have to do is assess the LEAK(s)...
and do a cost/benefit analysis...
If indeed the parts are available (they seem to be)
http://www.appliancepartspros.com/motor-pump-parts-for-frigidaire-fdb1050rec0.html
Then all you have to do is find the cause of the
LEAKS and repair them...
Mine turned to be rusted body panels...
(not much you can do there... Unless you
find a complete DONOR... Not unlike restoring cars...
(the labor of love)...
Check out other part houses...
Repair-clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Part-Select
PartSelect Appliance Parts and Repair Help
... and don't forget to check eBay.
I will confess the new PRO Series "QUIET" models
are VERY quiet... and sooo... pretty I had to REMODEL
the ENTIRE KITCHEN... (no savings there).
Hope this saves $$$$
Carnac the Magnificent
5 Related Answers
Anonymous
  • 159 Answers
  • Posted on Jul 12, 2007
SOURCE: Garbage Disposal backing up in dishwasher
Most dishwasher have a check valve at the pump to prevent water from backing into the dishwasher. If the pump is electric there is a rubber flat that may be gone or not working properly. If that is the case you need to replace the pump. If the pump is part of the motor assembly then the pump and motor will need to be replaced. One other thing to make sure of is that you have the drain hose looped to the top od the dishwasher and then to the disposal conection. Its called a drain loop and all dishwashers should have it. Good Luck
Anonymous
  • Posted on Dec 20, 2007
SOURCE: Frigidaire PLD2855RCO Leaking
The gasket at the bottom of the door where air vents in to allow for "drying" gets water splash that differs depending upon what is loaded in front of it. For instance, my dishwasher (Frigidaire PLD2855RFC1) leaks only when a certain spoon or something is loaded in a certain position or a pan is creating too much basksplash. That sort of dynamic simply excapes the repair types in a lot of cases. And the problem leak does not occur when the technicial tests it when the machine is empty.
You need to call your local repair folks and tell them to get on their "support service website" (that only they can get on) and look up Electrolux bulletin DW 071 which speaks to this issue. The offending and poorly designed "gasket" has quietly been redesigned and supposedly fixes this problem. Too bad they don't tell us about it. My serial number fell right in the middle of the units produced with this bad design. I will never again buy a Frigidaire of any type - ever. Nor will I deal with Coos Bay Area Appliance Store again. They all spoon fed me all kinds of accusations that it was installed wrong, unlevel, whatever. None solved my problem. THEY WILL SUFFER REVENUE LOSSES because of this. Good luck to you.
Anonymous
  • Posted on Feb 22, 2008
SOURCE: Dishwasher suddenly started leaking on floor?!
I have leaking from the screws holding the heating element of the same model dishwasher. The part is called heater nuts. I don't know if I need to replace the entire heating element assembly or just replace the nuts.
Any help is appreciated.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 04, 2008
SOURCE: my fridgidaire ultra quiet 3 dishwasher leaks...
a common place to leak on these machines is through the heater leads. run the machine w/lower panel off and see where its coming from , if its dripping down the heater leads, chances are the 2 nuts that secure them are broken and need replacing
Anonymous
  • 750 Answers
  • Posted on Oct 03, 2008
SOURCE: FRIGIDAIRE DISHWASHER FDB1050REC0 LEAKS UNDERNEATH
There are a couple reasons water may be leaking out the door of a dishwasher.
1. The water is most likely coming out the bottom of the door where there is no rubber seal.
2. The rubber seal is around the door jam on top and both sides and not on the bottom. This means if the dishwasher has to much detergent in it the soap suds push only the water higher than the front edge of the wash basin and out the bottom of the door where there is no seal!
3. Fill only the soap cup that can close for the secondary wash. The open cup is a pre-wash and mostly not needed unless the food is baked on.This just wastes money to fill both of them every time.
4. And if you are using liquid detergent you only need half the amount from the powdered soap!
try less soap. Remember to much soap too can cause the water overflow.
5. And the last would be that the drain is clogged and caused a back up large or small and then the overflow!
is there water in the bottom when the wash is done?
Soap is usually the culprit, not that there can't be a leak in an old drain or water supply hose!
Go with the soap idea first!
Let me know how you are!
How old is the washer ?
Please remember to leave a rating before you go!
Thank You ,Huuum
Why is our dishwasher leaking water
There are 4 places it could be leaking. 1) at the connection where the water line connects to the dishwasher. If the dishwasher has been in operation for a long time then this is not likely to be the problem. If this were the problem you would notice water even when the dishwasher was not running. 2) at the drain hose connection. You would notice the water during and shortly after a drain cycle. The drain outlet is usually a hard plastic over which the rubber drain tube is clamped. Either the plastic could crack or the hose could dry out and crack. 3) The seal around the pump could be leaking. 4) The door seal could be leaking, though this in not usually the problem. You can probably determine the problem by removing the bottom panel so that you can see underneath the unit, and then run a cycle. There are usually 2 screws between the door bottom and the lower panel (near the sides of the machine) and 2 more screws at the
bottom of the lower panel (the recessed part of the panel) near the sides. Don't stick your hand under there because you will have power to the unit and a wet floor. That is a bad combination which could be lethal. Just shine a flashlight under and see where the water is leaking from as it runs. Remove power at the circuit breaker before trying to do any service on the unit.
How do i remove the lower front access panel of my dishwasher
Should be less than 4 screws to take the bottom panel off. Now you might need to pull the unit out and have someone help you tilt it back to get to it completely.
Frostfree freezer leaking from lower front
From what you have described, without a model number, it sounds like the unit is leaking from possibly going into a defrost cycle. Check to see if you have any ice build up that is now melting or "slushy" in that general area. Water tends to run along the nearest plastic ridges and parts til it can escape underneath.
My asko dishwasher D 1716 is leaving a white film on my glasses and other dishes. I have added Jet Dry but it has not helped. Also sometimes water leaks under the handle and runs down the front of the...
Hi
The issue is with the water not draining as something might be blocking the drain pump assembly thus the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that is fine. Hope this helps...please post back for further assistance.
Daniel
I have a built in GE model GLD4400N10BB and it is not draining properly. Instead it is leaking from the bottom (looks like from the flood float) into the floor. It is 4 days out of warranty. Any...
Hi
Daniel
8helpful
There is water in the bottom of the dishwasher
Hello. Most likely you have a partial blockage in your dishwasher drain line between the floor of the machine where the drain pump may have debris in it and the trap under the kitchen sink. If you are handy you can remove the lower front panel of the machine, locate the small pump at the end of the drain hose, remove the pump to physically examine it and remove any glass or other debris in there and then check the rest of the drain line right to the trap under the sink.
Be sure to begin by turning off the breaker to the dishwasher to eliminate any shock hazard. J.
Dishwasher is leaking
If the unit has a removable lower front panel, take it off and slide a sheet of news print under the machine so that the leak will show as a wet spot on the paper. This gives you a clue as to the location of the leak. That position will lead you to a leaking hose, pump, inlet solenoid valve, door seal, and so on. Hope this helps!
Mar 19, 2010 • Dishwashers
Leak in left front need to remove lower insp. plate
Look for screws near the floor at both ends of the panel near the floor.  Remove those and you may be able to remove the panel with a slight lifting motion if the top of the panel is attached by a slot-and-hook of clips.  If it won't lift off look for screws in the top surface of the bottom panel or at the sides.
May 27, 2009 • Dishwashers
2helpful
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Top Frigidaire Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
