Posted on May 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vpl-cs6 projector problem - Sony VPL-CS6 LCD Projector Multimedia Projector
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 13, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
126
Points
Anonymous
Level 2:
  • Expert 442 Answers
  • Posted on May 29, 2011
Anonymous
Expert
Level 2:
Answers
442
Questions
Helped
176983
Points
703
3 Related Answers
projdoc
jasbo
  • 2239 Answers
  • Posted on Dec 08, 2009
SOURCE: my projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
Testimonial: "Thanks very much for the help. "
pl2323
  • 89 Answers
  • Posted on Aug 10, 2010
SOURCE: i purchased a new lamp
See http://www.avlamps.eu/projector-lamp-sony-vpl-cs6-_d9953.html for instruction how to reset the timer
Anonymous
  • Posted on Jun 21, 2011
SOURCE: My Sony Data Projector VPL CS6 is stuck in
I tried the emergency mode and recovered the powered mode. just make sure you can turn the adjuster ( that big grey plastic screw) freely and leave it that way (don't tighten it or put the **** back in). try turning it on. works for me..
Sony vpl cs5
Original lamp for cs5 USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Projector vpl cx21 cust the edges of the image
In the menus there should be an "image" adjustment option, it could also be related to the "sync" rate. Try different settings. You may also need to adjust the resolution you're sending to the projector from your computer.
Sony Vpl -cs6 Lamp hour reset Procidure.
Connect the power cord and turn on the projector.
When it's in standby mode, press the following keys on the remote in this order for less than 5 seconds each.
RESET
left arrow
right arrow
enter
I have Sony VPL CS6 projector and the lens cover stays open and wont shut to cover the lens!! The Lens/Cover light on it flashes? It does project for about 15seconds or so but then goes off, this is when...
It is possible that there can be few reasons for the fault siad:
1.the lamp can be faulty
2. the filter can be clogged.
3. the lens cap trigger switch can be faulty and staying on
4.The power supply can be faulty, not delivering the power but shuts off.
5,the main processor board can be faulty witth errors.
It might need board swapping to confirm.
2answers
My Sony Data Projector VPL CS6 is stuck in emergency mode, can it be reversed.
My VPL CS6 will not turn on. I tried different cords and power points and the dust and lamp covers are securely closed.
It could be that you have put the projector into emergency mode. If this is the case you can only switch it on by moving the small switch by the leg tilt underneath, and then maually open the lamp cover by turning the adjuster with a coin, see page 48 of the manual for instructions. Hopw this helps
3helpful
My projector sony vpl cs6 projects yellow
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
