Hi.
Controlling subtitles with the Logitec Harmony Remote Control is exactly the same as controlling any other action. You just need to set up the Harmony to send the correct command/s, as follows..
- First it depends what 'Device' (AV component) puts the subtitles onto the screen, so you need to check the instructions for that device.
e.g. if that device is a TV, then check the TV's original instructions to find out what menu item is involved, or what button sets the English subtitles.
- Next, if the example above applies, look through the Harmony 600's Device page for the TV and see if you can identify the corresponding control buttons. If they are not present already, then teach the commands to the 600's 'Device' buttons for the TV, using the TV's original remote.
- Finally look in the Activities 'Customize Buttons' page to make sure that some buttons are configured to send the commands you need. If they aren't, or if they are not available, then program those instructions into the 'additional commands' for the relevant Activity/Activities.
If several button presses are needed then you could possibly even 'Add a Sequence', in the relevant 'Activity/s' page/s to do the job, and call it something like 'EsubSeq'
Regards
Chas
