This typically indicates an open circuit to the freezer sensor. You should be getting an 'F' code as well. Can you provide more information or have you had the problem fixed. If it was fixed, it would be great if you could let us all know what was done. Tx.
I can not find parts for my liebherr refrigerator
SOURCE: Hi. I have a Liebherr
the problem is the defrost. this could be;
\defrost timer
\ defrost heater
these are live components and should be tested by a technician
SOURCE: alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
SOURCE: fridge drain not clearing
Try clearing it a little better. Use some kind of pipe cleaner then flush with hot water. Good luck
SOURCE: Wher can i get parts for my liebherr premium ctnes 4753 nofrost
try using frosted glass(toughened)more permanent,use a plastic shelf as a template.....
SOURCE: Hi we have a liebherr premium biofresh fridge and
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
