Watches Logo
Posted on May 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i replace a 5.5 x 1.6 1.55 battery on a swatch
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on May 19, 2011
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814241
Points
13579
Swatch batteries should be replaced by removing battery cover on the back. If there is no such a cover, it can be done by taking out watch glass. The latter should be done by watch repairer, for it takes a lot of specialized tools and skill.
tip
SWATCH - how to change battery in SWATCH watches
Follow this link and see how to change battery in your SWATCH watch:
http://www.swatch.com/templates/zz_en/pdf/manuals/battery.pdf
on Aug 04, 2010 • Watches
2answers
My Swatch Irony watch has recently been running slow. I thought it might be a low battery, but after a replacement, it still loses time (a few minutes each day). Any ideas?
Thank you for contacting Fixya,<br /> I would have the battery checked again. Sometimes batteries in stores can be past the extended life of battery. Otherwise could be a number of issues. Has it been around water? Dropped? Could need cleaning. In cases of most watches, like Swatch, the cost to have repaired may exceed the watch. <br /> You can contact Swatch at:<br /> <a href="http://www.swatch.com/zz_en/shop.html">http://www.swatch.com/zz_en/shop.html</a>
Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
My swatch model is swatch irony YSS112G. It stops working and when i took it to swatch shop the assistant told me its due to the mechanical problem since a new battery was restored. i was told that it was...
mcdevito75 here, Once any Quatrz mechanism goes, it"s ususlly gone. New replacement Quartz mechanisms are sold but just the mechanism itself could cost $30.00---$70.00 then the labor to have it installed, A Swatch watch is a COLLECTABLE item, it may be worth the expense of a new Quartz Mechanism, spaek with the watch shop about details.
Jun 27, 2010 • Watches
1helpful
How do you open the case of a Swatch skin watch?
the swatches are sealed from the factory.the only that you can do is to change a battery!
Put in new battery and it does not run.
It is because some 317 batteries have their negative terminal plate flashed a little bit into the positive side plate and some are a bit thicker thus the negative plate of the skin swatch touches the side of the battery. sometimes battery cove/lid cannot be closet when the battery is a minute thick. renata battery is just right for the skin swatch.
1helpful
Hye...my watch swatch stop functioning even i already changed the battery.
Could be Following Reason
1, Watch movement required overhaul
2, Circuit or coil warn out
3, Battery connection are not on right place
4, Test new battery to check its strength
If watch has only battery cover on the back and does not has backcase
like most of swatch watches are then watch can not be overhaul.
hope this information is helpful
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
2helpful
Swatch Skin #SFK254 ,Time always late
Simply pry the battery cap off and remove the battery for at least 24 hrs. to depolarize the watch.And then reinsert battery and snap cover on.Your skin is back in order.Good luck.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
