The 199A is not designed to be a wireless controller. It was designed long before wireless control of flash units was available in consumer flash units. You'll need to use the built-in flash, a more modern Canon (or compatible) controller, or some other wireless setup (possibly radio).
Bruce, Try these steps: 1. Set camera to manual2. Set shutter to 1/60 3. Set aperture to F5.6 4. ASA/ISO 200 5. 550EX on hotshoe 6. Do not set on slave or master 7. Turn on flash
Display must shows, ETTL. If that doesn't work, you have to use the flash on manual. Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me. But that can be costly when you can get the 580EX II for less than $425.00 USD.
You probably haven't calibrated your monitor to show the correct colours, so in whatever photo programme you're using, you're setting the red tones too high. Test this by first not calibrating your monitor, but turning down all the red tone until it looks washed out. Print this and see if it's better. If so, set your monitor to a cooler colour temperature. If the result is no better, check your print dialogue settings to make sure you are using an appropriate colour profile. And, for example, if you're using Photoshop, tick 'let Photoshop manage colours' in the advanced profile settings box. Hope this helps. I doubt there's anything wrong with the printer.
You didn't say what camera model you are using. If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1 Two 270EX II must be set at Slave, say Group A & Channel 1 or One 270EX II set at Group A & Channel 1 Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Configuring communications settings in FTP mode1. Select [Address setting] with the camera's Quick Control Dial. 2. If you choose [Disable] for DNS server setting, enter IP address. For [Auto assign], enter server name. For [Manual setting], set up IP address. 3. Set up [Port No.] usually at 0021. 4. Configure [Proxy server]. 5. Configure [Login method]. 6. Set [Target folder] to [Root folder] or select folder using [Select folder] menu. 7. FTP server connection is established. Note: Settings can be stored in the camera.
Configuring automatic image file transfer in FTP mode1. Select [Set up] in [WFT settings] menu. 2. Choose [Automatic transfer].
Configuring communications settings in PTP mode1. Select [OK] from Pairing screen. 2. Start WFT Pairing software on PC. 3. Double-click the icon inside PC task bar. 4. Select the WFT-E2/E2A/E3/E3A/E4/E4A [MAC address] you want from on-screen list of cameras. 5. Connection to camera is established. Note: Settings can be stored in the camera.
Remote control of cameraOnce you start EOS Utility, you can control the camera remotely, using all available functions.
So you have a Nikon D300 with Nikon Camera Control 2 running on Window 7. Do this first:1. Remove Nikon WT-4A from camera.2. Make sure to set menu to PTP.3. Hook USB cable from camera to computer (tethered).4. Turn on D3005. Something will display on lower right screen ei found Nikon D300.6. Click on Nikon Camera Control Pro 2 (what version do you have)?7. Wait about 2 to 3 minutes for Nikon Camera Control Pro 2 to come on.8. Adjust modes & settings from pc and fire from pc, not from camera.9. One or two of your cells is defective or weak. Battery goods for up to 3 years. You can check with DVM.10. Many are having problems using & setting up Nikon WT as well as Canon WFT. All are now selling them and using my ATG AK1 Un-Tethered Systems.
If the problem still happens after multiple resets contact the place you bought the camera from and see if you can get a replacement. If the camera is still under warranty canon will try and repair your camera and won't replace unless it is unable to be fixed.
You do not use lubricant on printers. Clean all roller and bars with Q tip and acohol. Make sure alcohol is squeezed out so it does not drip inside printer. The noise should stop. If it does not it is the belt that drives the capstans (rollers) that is worn out.
start here: http://software.canon-europe.com/ Select Cameras --> EOS-1D Mark II On the next page select: Language --> Spanish Click "Submit" The Spanish manual will be the first download in the list.
