Microwave Ovens Logo
Posted on Apr 19, 2011
Hi, I have a Daewoo KOC1BOK (3D Power 1000w) convection combi microwave oven which has suddenly stopped heating up on convection mode. It still works fine on the microwave setting. Anyone have any idea what the problem could be and how I could go about sorting it? Much appreciated!
5 Related Answers
VEKAT
Devabhakthuni Venkateswara Rao
  • 225 Answers
  • Posted on Dec 12, 2007
SOURCE: Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Anonymous
  • Posted on Feb 26, 2008
SOURCE: Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 20, 2008
SOURCE: My LG Combi Microwave oven
This is usually caused by either a bad door switch (usually the top one), a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
A
Anonymous
  • Posted on Aug 18, 2008
SOURCE: Panasonic NN-CS596S Convection Combi Steam Oven
Thanks for this. Thats exactly what I did. It didn't work at first, however, I think it was my impatience! After selecting the Microwave, you MUST wait until you are told via the screen to input the time. It now works fine. Thanks again. Just needed perseverance! Mike
Anonymous
  • 25 Answers
  • Posted on Jan 14, 2009
SOURCE: Daewoo WM1010CC convection/ microwave combo unit issues
Likely takes a torx wrench or some other special star tool to open it.
Could be a bad relay a bad mag tube or a bad timmer or a bad door switch. Needs to be trouble shooted. You have to get it open and check the fuses and test the voltage on the pri transformer first.
I have a Sharp 963 combi oven.. The microwave has stopped heating everything else is working.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ]
Microwave not heating anything? everything else work
heatman101
fgshg
Sparks coming from back of microwave
If you coffee container had any metallic logos or paint on it sparks will occur. Try to heat water in the glass container.
Convection function not heating from underneath
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
My kenomore Microwave has pwer and has stopped heating
heatman101
0ut
Top Daewoo Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
