Hi
Error code SD means LONG DRAIN. This error appears when the drain time exceeds
8 minutes and the water valves turn off. After 4 minutes the "Sd" error will be
displayed, and then 4 minutes later the F21 error code will be displayed. Press
PAUSE/CANCEL two times to clear the display. Please Check the drain hose
and make sure it is not plugged or kinked. If the drain hose if fine then
unplug the washer and check the electrical connections at the pump and make
sure the pump is running. Check the drain pump filter for foreign objects. To
access the drain pump and filter remove the front kick panel and trace the
drain hose to the bottom of the washer, drain pump would be located there. If
you are not able to access it, then replace the back panel as well. Plug in
washer or reconnect power. If the issue is still not resolved then you would
need to replace the drain pump.
Hope this helps... Please post back if you need more information.
Daniel
Hi
Error
code SD/5d means LONG DRAIN. This error appears when the drain time exceeds 8
will be displayed, and then 4 minutes later the F21 error code will be
displayed. Press PAUSE/CANCEL two times to clear the display. Please Check the
drain hose and make sure it is not plugged or kinked. If the drain hose if fine
then unplug the washer and check the electrical connections at the pump and
make sure the pump is running. Check the drain pump filter for foreign objects.
To access the drain pump and filter remove the front kick panel and trace the
need to replace the drain pump. Hope this helps...please post
back for further assistance.
Daniel
Hi
Error
Daniel
Hi
Error
Daniel
Hi
Error
Daniel
Hi
Error
Daniel
