Follow these guidelines: WebRepOverall ratingThis site has no rating(not enough votes)
Update the browser
Clear history and cookies
Delete temporary internet files
Stop all those unwanted programs that consumes internet.
If problem still occurs then use system utility tool Intel Software partner Reginout. This tool will also fix internet problems by running its Internet Optimizer feature.
Check your startup programs Start>Run>Type msconfig in the run window In the system configuration window go to the startup tab From here you can disable startup programs
Disabling startup programs will only stop them from stating up. The programs will work as normal they wont run in the background if your not using them.
the problem is u have a lot stored on the pc memory and when this are much it slow down your computer so what u need to do is check your desktop and delet some things u no longer needs or dont open too much pages on your home page this can make your pc slow down ok,thnks .
You are very lucky that you know the date the problem started. This will make it easier to find out what caused this slowness. I'd suggest you go and check your firewall reports up to yesterday's date to find anything strange and run a malware scan. Slowness can indicate spywares that utilize your system and grind the hard disk for the information it is programed to collect. Also check if there were any other installations that took place yesterday which may have corrupted the system or is incompatible with the system. If my suggestions work, please do rate me. Thanks
1. delete temporary internet files.
2. run disk cleanup then defrag if needed.
3. if you need help doing these tasks i'l gladly walk you through them.
4. empty your recycle bin
Often times, when a PC has be used for a long period of time, information becomes fragmented on the disk, causing read errors and various problems similar to what your experiencing.
To rectify this issue:
Start > All Programs > Accessories > System Tools > "Disk Defragmenter"
I would also suggest using a free tool called Ccleaner. This is a wonderful maintenance tool.
Please visit this site for the download: http://www.ccleaner.com/download
This utility coupled with a defrag should solve your issue.
Please let us know if you have any more issues, as it may be related to Malware.
If you found this information helpful, and it solved your problem, please take a moment to rate the solution. Thank you.
type into your search engine------avir free------ and download the avir antivirus free program. It is super terrific and will definitely get rid of your whatever you have. I have tried a large number of those programs, include some I paid for, and none of them stand at the front door and keep stuff out. All of the others will get rid of it once it is already in but this one stops it from entering. It is the only program I would use for stopping and getting rid of viruses, worm nd malware.
i had the same problem with my computer. it may be that you have downloaded too many things. it loads onto your RAM storage, (computer files), and when it gets full, it goes onto the harddrive, (where you access files and things). clear up internet files and anything you don't need. if that is stilll slow upgrade your RAM. it fixed my pc
