SOURCE: Jabra BT500 won't turn on or indicate charging
Hello all...
I had this exact same problem, and had a couple hours on my hands to kill, so I opened up my headset. ***PLEASE NOTE - This WILL void your warranty*** Once the headset was open, I took a quick look around, and noticed that one of the leads that attach the rechargable battery to the little circuit board was not connected. Being somewhat handy, I was able to use my soldering iron to re-attach the lead from the battery to the PCB. I plugged the unit into the charger to verify, then carefully put everything back together. A little dab of superglue in the joint above the volume controls, and my headset now works great! Be careful when putting the unit back together, as the first time I re-assembled it, the lead came off, and I had to take it all apart and re-solder it. The circuit board will move out of the way slightly (pulls away from the case) in order to give a better angle to solder the lead. It does not fully detach though, so be careful. In total, it took about 30 minutes of my time, which is way cheaper than a new headset =)
Tim
SOURCE: jabra bt160
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2)
For optimal performance, wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight. In general, you will get better performance when
there are no obstructions between your headset and your mobile phone. (See fig. 5)
Answer a call
• Tap the answer/end button on your headset to answer a call
End a call
• Tap the answer/end button to end an active call
Reject a call (Dependent on your phone supporting this feature)
• Press the answer/end button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (subject to phone
settings) automatically transfer to your headset
Activate voice dialing (Dependent on your phone supporting this feature)
• Tap the answer/end button. For best results, record the voice-dialing tag through
your headset. Please consult your phone’s user manual for more information about
using this feature
Redial last number (Dependent on your phone supporting this feature)
Adjust sound and volume
• Press the volume up or down (+ or –) to adjust the volume (See fig. 1)
5 How to...
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode
Make sure that the headset is on.
Press the answer/end button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT160
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’
‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’
or ‘add’ a Bluetooth device.* (See example from a typical mobile phone in fig. 4)
3 Pair it with your phone
English
2 Turn on your headset
• Press the answer/end button to turn on your headset
• Press and hold the answer/end button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
Here is what you do, first get yor headset, hold it up in the air, then grad a hammer and smash it, that should do it.... Hope this was helpful
SOURCE: Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
