GE (PSS26MSRSS) Side by Side Refrigerator Logo
Posted on Oct 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE side-by-side refrigerator, Model GSH22JSTA-SS. It has never been used and I would like to sell it, but cannot find the model number among current appliances. It came with a condo and I have another model I will use. I need to know the year the JSTA was made and how much it sold for. Can you help? Thank you.l H. Pieratt
Lawrence Oravetz
Level 3:
  • GE Master 10,558 Answers
  • Posted on Oct 30, 2017
Lawrence Oravetz
GE Master
Level 3:
Answers
10558
Questions
Helped
2700613
Points
29284
Look for the information label inside the refrigerator side usually near the top of the box. It will have the model number and date of manufacture on it.
5 Related Answers
Anonymous
  • 103 Answers
  • Posted on Jun 01, 2009
SOURCE: Freezer is freezes it self up and a giant block of ice froms but refrigerator is warm
Hi: your model number dosn't get a match on a search. Did you check the defrost heater? I hope this helps Jeff,
Anonymous
  • Posted on Jun 13, 2009
SOURCE: GE side by side - upper freezer warming once a week then freezing
Had the same problem. Bottom of freezer was about the right temp but the upper part was way too warm. Fridge side was fine. Ice maker stopped making ice - it wasn't broken, but it won't run through its cycle if the temp is too high. Cubes already in storage hopper melted and water refroze as it ran to lower, colder part of fridge. Problem: Fan controller for freezer compartment was faulty. The fan itself was fine. Fix: GE replaced the main circuit board that controls everything on this model, including the freezer compartment fan. Once that was done, temp returned to normal, ice maker is happy again. The board had undergone several revisions from the factory installed one (could tell this by comparing the part number on the old and new boards - they increment it when they revise it.) Bad news: the part/labor were expensive and of course failed after the warranty ran out. Good news: the board is now guaranteed for 5 yrs. (Why wouldn't the factory-installed board ALSO be good for five years instead of just one? It's not like the replacement boards are made better.) Labor is covered only for 90 days though so it won't be free if they have to come back after that.
Anonymous
  • 520 Answers
  • Posted on Jun 15, 2009
SOURCE: CANT FIND A NUMBER ON THE WATER FILTER INSIDE THE REFRIGERATOR
The part # is MWF and a good site to help with these sort of finds is www.Appliance411.com And it will lead you to nearly any part or accessory you may need.
Anonymous
  • 1543 Answers
  • Posted on Aug 04, 2009
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Anonymous
  • 66 Answers
  • Posted on Dec 12, 2009
SOURCE: I have a GE refrigerator side by side that is 2
If the refrigerator is not cooling it could be for a couple reasons.
Either there is an excess of ice buildup between the freezer and the refrigerator or the compressor is bad. If its just and ice buildup all you need to do is remove the ice by either defrosting the refrigerator or using hot water poured down into the air vent inside the machine.
If its not the ice, its probably the compressor in which case you would have to get a professional to come and replace it which is rather costly. In most cases you are better off buying a new machine rather than replacing the compressor. Especially since it is not that old and is already having a major problem. If you decide to buy a new machine I recommend Whirlpool brand appliances.
Where Is The Defrost Timer Located On My Ge Refrigerator Model GSL25JFTABS
Where is the defrost timer in my General Electric freezer model number PSS26NSTB SS
GE refrigerator model number PSS26SGRE SS quit. Lights come on and only digital readout is hours
the mainboard/motherboard in the rear area needs replacing the number is G.E.part # WR55X10942 it merely unplugs and plugs back in with 4 to 8 harnesses depending on your model and accessories
I have a GE refrigerator side by side that is 2 years old. We noticed last night that food wasn't very cold, so we checked the temperature setting. The setting is at 9 the coldest, yet it doesn't seem to...
1helpful
2helpful
Replace an Interface Disp ASM on GE side by side
Part number WR55X10415 . Pull out from the bottom of the board , may have to use a small screwdriver to pry outward from the bottom to remove . Would suggest removeing top cap on freezer door and unplugging connector first .
GE Side by Side Fridge Problem
could be defrost problem. check frost pattern on evaporator.
Top Refrigerators Experts
vince
Johnny 1000
