Hi i'm trying to programme my sharp stereo with a sony rm vz220 remote control. But can't get the correct code. The only code that i got was 60048. But it does not work.. Help plz..
According to the Sony Support site for this remote, receivers are NOT supported at all. Additionally, only a handful of codes are available for Sharp electronics. They are for the following devices:
Blu Ray, CD, DVD, DVD Recorder, TV and VCR.
All the codes used for the devices above are:
12250, 70034, 70037, 70180, 10630, 10675, 12250, 10675, 00818, 60048 and 60848.
You could try these codes one at a time and possibly gain some remote control capability - but that would only happen by chance. The codes above are the ONLY ones built into the RM-VZ320 remote for Sharp brand products, and if none work for your equipment, Sony says you should use your original equipment remote to control it. Not very helpful.
You can either do as they recommend, buy a pre-programmed remote that supports your device, or buy a pre-programmed remote that supports "learning". Learning remotes are universal in that the products not built in to the remote can be learned by holding the original so it points at the learning remote and pressing function buttons so that the learning remote "records" the buttons pressed on the original. It can take some time to do this, but you are assured that the remote will work with you device. Of course, you must have the original remote to do this though.
I hope this helps and good luck! Please rate my reply. Thank you.
