Hello elscomputers: If you are sure that there is no other issue with the motherboard -- It was working before the CPU Fan/Heatsink stopped working. Other than making sure that it is correctly connected as shown below -- attached to Pin 1 with all three pins connected (not off to the side by
one pin), you can assume it's bad (they do wear out). The cost of a new cooler is pretty minimal and I would just replace it.
Good Luck and Thanks for inquiring at Fix Ya.
Mikeywaf
Elscomputers
Hello, Thank you for your visit to our expert site.
If you are SURE your cpu fan is in operative order then your motherboard settings in the bios or that actual plug is not putting out the power for that fan to run! You could try another plug on the main board but if you cpu fan's cord has enough length.
Fan is good the main board is not providing power to fan or setting in bios might be off ether or it sounds from your user name that your a company witch I would recommend you to Gigabyte directly due to conflicts of interest!
1. Try a different cpu fan in that motherboard plug to verify that its passing the power. If the new cpu fan does not work then you know its the motherboard.
2. If the new fan spins then it is indeed your cpu fan.
Thanks,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
