20 Most Recent Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard Questions & Answers
Continually blinking beep..!!
cmos pin reset then take out battery then wait one min put it back or you will need to recover bios by reflash them to factory setting
5/18/2014 9:52:36 PM • Gigabyte... • Answered on May 18, 2014
0answers
Download ethernet
Be the first to answer 1/26/2014 5:45:06 AM • Gigabyte... • Posted on Jan 26, 2014Be the first to answer
My pc always shutting down whats the cause?
Hello here is the homepage:http://www.gigabyte.com/products/product-page.aspx?pid=1863#dlMine did that once; it turned out to be the power settings, in the control panel.Have you downloaded any files recently?If you download a bad file that contains a keylogger, it usaully shuts down the pc, it has happend to me. The problem could also be dust or overheating, lack of ram memory,harddrive failing, dryed out thermal paste, between the cpu and the coolling element.Try to scan for virus with this:http://www.malwarebytes.org/products/malwarebytes_free/And renew the antivirus program for free:http://windows.microsoft.com/en-GB/windows/security-essentials-downloadI recommend not to use more than one antivirus program.Good luck
2/5/2013 3:18:07 PM • Gigabyte... • Answered on Feb 05, 2013
Hi all ive got 2 512mb and ive just put in 2 1
You probably need to flash your chipset in order to take that much memory in your pc. What kind of computer is it? what operating system are you using? did you check the specs to see how much memory is the max that your system can take? What chipset is installed? Try removing some of the memory to reduce the load, then flash your bios and reboot. Add the rest of the memory and see if that solves your problem and allows the pc to load as normal.
10/26/2011 3:07:09 AM • Gigabyte... • Answered on Oct 26, 2011
Hi, When I start run that
Hi, you can download a manual here:
My guess is that your have a failure in:
The hardrive because you get a blue screen
its a typical problem when windows not loading normaly
could be a bad sectors on the drive.
The ram
Or the cpu due to maybe over heating
Or the mainboad is simply have a defect.
8/25/2011 9:21:25 PM • Gigabyte... • Answered on Aug 25, 2011
Win Me will not Boot
Try just using 512Mb of memory or less as there was a bug in Me and 9x that produced that error if you had more than 512 Mb of ram.
7/18/2011 8:25:41 PM • Gigabyte... • Answered on Jul 18, 2011
2answers
Motherboard wont power on with
No, a failed processor would still generate a beep, the northbridge has failed - this motherboard is dead.
6/10/2011 8:43:39 PM • Gigabyte... • Answered on Jun 10, 2011
I can't connect internet although
first you must have an ISP Internet Service provider contract which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the internet or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts to set up your new internet connection during the setup process you will be asked for a password I suggest you make a log of all pass words used outside of your computer incase of memory lapses if you already have the internetyou might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall a yellow? question mark means you need to install/update driver right click to install driver last resort ring your ISP internet sevice provider get them to check your modem for internet access online hope this helps
5/22/2011 1:25:25 AM • Gigabyte... • Answered on May 22, 2011
Ptowreplaced power supply worked 2
It is possible that you might be overloading your power supply unit. Go to this website and calculate how many watts you need for your system. You just have to select the components in your system from the drop down menus and it will calculate your power requirement.
http://extreme.outervision.com/psucalculatorlite.jsp
After getting your power requirement (in Watts), replace your power supply with a unit rated at least the recommended PSU wattage. Also note that cheap power supplies usually do not reflect the true wattage output on their labels. Try to get a power supply unit from reputable PSU manufacturers like Antec, Coolermaster, Thermaltake or Corsair.
3/23/2011 2:31:07 AM • Gigabyte... • Answered on Mar 23, 2011
Hi My MB is Gigabyte GA-8IPE1000
hey.. if your chipset is getting heated badly. then that is a big problem..may be because you don't have proper cooling solutions in your cabinet, and now if it is not starting that means some of it's components like capacitors are blown off. you might have to buy new MB or if this is in warranty period then try to replace. and put some fans there dude good luck!!
3/3/2011 5:26:03 PM • Gigabyte... • Answered on Mar 03, 2011
HI, When I turn the system on it powers on ,with
Hello, The constant beeping that you are hearing is due to the memory sticks not being recognized or installed correctly. Please check your manual for the motherboard to make sure that the type being installed on the motherboard is the same listed in the manual -this is most likely the problem. If they are compatible then perhaps the cards are not seated fully in their sockets or in the wrong ones for your board.
Good Luck!!
1/31/2011 6:20:01 PM • Gigabyte... • Answered on Jan 31, 2011
Mother is very noisy
Change the fan of your CPU.
this problem often caused by damaged CPU's Fan.
1/13/2011 12:48:40 PM • Gigabyte... • Answered on Jan 13, 2011
Can i use a ddr2
According to the Gigabyte website
http://www.gigabyte.com/products/product-page.aspx?pid=1863#sp
that motherboard only has DDR slots (4 of them), so, no you cannot use DDR2 RAM modules.
If you do manage to make it fit, the pins won't line up because DDR can be 184pin or 200pin, and DDR2 can be 214-pin, 240-pin, 244-pin.
Since your memory slots or only DDR, there is no way that the DDR2 would make the connections that it would need to make in order for it to work.
I hope this helps! If not, please comment back and let us know!
12/30/2010 1:47:04 AM • Gigabyte... • Answered on Dec 30, 2010
2answers
Win xp sp 3 audio driver
try with link below
ftp://63418efdb40d74059eb057d0503f2a33:[email protected]/soft/drivers/pilote_audio_realtek_a4.06_970.exe
12/19/2010 11:31:41 AM • Gigabyte... • Answered on Dec 19, 2010
I want driver for multimedia
There is no official driver for this motherboard for Windows 7 op. system. I suggest you to use the win XP 32bit version (in case you don't have it, here is the link to download it). Download it at your computer, right click on it, click on properties, click on the compatibility tab and choose compatibility for windows xp, sp3. Click on apply - close. Run as administrator the installation file.
This problem is very common with old hardware and windows 7. At most of the cases this trip works.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
12/5/2010 7:38:19 PM • Gigabyte... • Answered on Dec 05, 2010
Hey, the computer starts with
May be the RAM Problem
For solving the problem do the following:
1. Remove the RAM(s) from its positions / place from the mother board
2. Clean the RAM slots inside the mother board with a neat and dry brush
3. Rub the "RAM (Copper Bottom) with an eraser or with hands gently for a few seconds.
4. Place the RAM in their slots and restart the system
Let me know! that i Fixya the problem
Thanking you.
B.Krishnamacharyulu
11/8/2010 5:13:49 PM • Gigabyte... • Answered on Nov 08, 2010
Please would you help me
One bad lead will cause your computer to shut down or continue in a cycle replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to your hard drive hope this helps
10/23/2010 8:33:01 PM • Gigabyte... • Answered on Oct 23, 2010
Computer doesn't start-up anymore, goes
One bad/faulty lead can cause a computer with lots of problems replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
10/3/2010 9:15:42 AM • Gigabyte... • Answered on Oct 03, 2010
I have a 350W on
Use the link provided below to calcuate what size power supply you need depending on what is connected to your motherboard.
http://www.journeysystems.com/support/calculator/
Mike
9/6/2010 1:48:01 PM • Gigabyte... • Answered on Sep 06, 2010
Gigabyte GA-8IPE1000-G (MBGA81PE1000G) Motherboard Logo
58 questions posted
Top Gigabyte Computers & Internet Experts
MegaByteMe
MegaByteMe
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gigabyte Computers & Internet
Most Popular Question
all ive got 2 512mb ive just put in 2 1
  • Computers & Internet
