Fuel reg. is connected to the fuel rail where the return line is connected, my thoughts are you mentioned air in your lines.. crack open fuel lines and run fuel pump to release air from lines. Pump then should prime all lines must be primed turn engine over to release air ( No Smoking) then tighten lines. fuel rail might have valve, (looks like tire valve) if so it is recommended that air is relieved at air valve
i have a 1988 nissan 4 nwheel drive with a z24 motor .where is the fuel pressure regulator? it floods every time i start it but it runs and drives great.
