You will have to do a factory reset, which will restore the default settings on your device.
1) With the device powered off, press and hold the Volume Up and Power buttons at the same time.
2) When you see the Samsung logo, release the Power button, but continue to hold Volume Up until the recovery screen appears.
3) Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4) Press Volume Up to continue.
Mohamed Samir Elbaramony
Go to menu -> settings -> display and look to see if the "auto-rotate screen" option is checked.
If that doesn't work, try restarting. See if it works in browser.
Razer edge pro has this auto rotation problem also HELP!!!
If it keeps from rotating there may be an issue with your logic board. can get the part at Galaxy Tab Repair and there is a guide that shows you how to put in the part at Galaxy Tab Repair Guide.
I have reset, but still with the same issue! the screen still showing up side down, and just rotate to one side... Can you help me?
