It is possible that there is a fault in the INDETECT section of the cassette detection.
Normally this is triggered when the cassette is pushed into and if there is no detection the loading motor does not work nor the lock is moved to let the tray move on into the loading tray.
So when you put the VCR ON/OFF the detection motor works for a small period of time as a pre check which in the process allows the motor the load the cassette into the section but while it is inside the processor does not get the INDETECT or the IR END sensors to work thereby allows the rejection to be ejected out.
You will need to check the loading detect sensors and the IR sensors for the fault described.
