20 Most Recent Emerson EWC1303 13 in. TV/VCR Combo Questions & Answers
Your over voltage circuits(hi-voltage and low voltage) are defective.When the voltage exceeds the specs it shuts off the tv.Unless your a service tech,you can't fix this.There are components on the main circuit tha t have to be changed.Sorry, no easy fix.
Emerson EWC1303... | Answered on Aug 25, 2019
You have built-in features that correspond between the TV and The Hand held controller designed by Emerson. Universal remotes are lacking some features that are necessary for full function of the TB. In your case, you may be required to replace the hand held unit with another exactly alike and with all of the functions you are accustomed to.
Emerson EWC1303... | Answered on Feb 04, 2018
Try doing the auto scan first to get all the possible channels.. Usually the Add/Delete function applies once the TV knows what channels are out there to add or delete.
Emerson EWC1303... | Answered on Jan 23, 2018
I would just replace the TV unless you have the skill and tools required to fix the problem with the old one.
Emerson EWC1303... | Answered on Jun 08, 2017
turn on the machine. use your figure push on the cassette, when you feel the cassette can't go any farther (don't jam it),and hold it there. press the eject button, you may have to try this couple of times in order for the cassette to come out.
the cassette deck need to have the drive belt change.
Emerson EWC1303... | Answered on Mar 12, 2014
This first link provides the procedure on how to program the remote http://www.mydish.com/support/program-to-tv-code-non-basic?WT.svl=contentArea This second link will provide you the codes needed to program the remote to the TV (The top line would be your remote model # you will find this number on the back of your remote, make sure that is the one you enter) http://www.mydish.com/support/apps/remotecodes.aspx?WT.svl=leftnav If you need further assistance please let me know. Once you have obtained the codes that can address to your television you follow this procedure to program the remote. (Which is the procedure provided on the first link)
Press and hold the clear TV button at the top left hand side of your remote for 5 seconds (all the other clear buttons will light up) once this happens enter the code followed by the # button on your remote, the clear TV button at the top will light up 3 times, this means the remote has been programmed. You can verify the remote has been programmed by trying to up the Volume, once you verify it works be sure to press the SAT button at the top left once (to set remote back to SAT mode and avoid other problems) Feel free to contact me at: kimberly.escobar@dish.com if you need further assistance.
Kimberly Escobar
Social Media Representative
DISH L.L.C
Emerson EWC1303... | Answered on Sep 12, 2013
Disconnect the VCR and leave the TV on and see whether the TV gets off. If it gets off, the timer in the TV is the one that has to be reset. I do not think there is any way a TV can be switched off by a VCR, unless the power supply is controlled by VCR.
Emerson EWC1303... | Answered on Jul 03, 2012
POWER SUPPY BOARD
Emerson EWC1303... | Answered on Jun 08, 2011
Hi:
Check on your remote for a button labeled CC or check you setup meny under setup for the closed captioned option and set to off posistion.
Emerson EWC1303... | Answered on Apr 20, 2011
Hello
If your other TVs work on the same antenna, and only this Emerson doesn't work with it, eiter your TVs tuner inside, or it tuning has some trouble. Check by put the set to autotune refering to its user manual. Check whether the cable socket is tight or not.
If these are correct, replace its tuner, [it is inside the circuit board], with same type and number. OK.
Emerson EWC1303... | Answered on Apr 11, 2011
Emerson EWC1303 13 in. TV/VCR Combo Logo
63 questions posted
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Emerson Televison & Video
Most Popular Question
want remove closed caption
  • Televison & Video
